Import system, select sites then talk groups and pick playlist and you're set. (Go to import, select standard then state, etc)
When you go to the import, use standard, go to your county and select the system you are interested in, under the sites pick whatever is appropriate (not knowing what system we are talking about) and then go to the talkgroups and just pick the 5 or whatever you want.
Then pick a scanlist and import.
You will have the system with needed sites and it will only listen to the talkgroups you picked.
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
Look again. When you select import, it then asks you which scanlist. I can't remember off hand if there is another button to click or it just does it.
Either way, if you at on the import section and you finish, the way you do it is by selecting import.
What he did should give him what he wants without the wildcard issue. You have to take additional steps to set up a wildcard talkgroup under a system.
At the bottom, see tab "LIBRARY IMPORT"
If you want to put them in another scan list from the screen that you are showing, double click the individual lines in the scanlists area and then you can put what you want in the scan list from the pop up window.
