Hello everyone...I am new to DMA Scanners so this may be a newbie questions...I am trying to add a new Trucking System using the import function from RadioRef. I select the sites and the talk groups I want and click the Import button. It will import the Talk groups with no problem but it will select the first site and not import any frequencies. If I try to add them manual it tells me there is not enough memory. I understand that the scanner it's self has a memory limit (I am using a Uniden BCD396XT by the way), which is only at 37% used. I can however add Conventional systems with no problem.
Any help or thoughts would be great
Thanks for your help
