vernongt
Hello all,
I was given, by my wife, a Whistler WS-1025 Desktop Radio Scanner to be used on my bedside table.
I didn't want to use one of my Pro-163's or Pro-652's as there was way too much radio for just a bedside table model.
Anyway, I purchased Butel ARC-404 programming software [CD version] in order to program this radio via Radio Reference's Database. On the Scanner Master website, It indicated that this was the software to use, even though nowhere on the software does it indicate WS-1025.
After receiving the software and installing it in this laptop [and using the RS 20-047 interface cable], I discovered many channels that would lock up during SCAN [Channels 30, 31, 32, 33, 34 & some in the 130's just to name a few.
I decided to "Initialize" the radio to ensure it was pristine and began to program the radio once more. I used different frequencies in different channels to see if there was a mild possibility of "Birdie Frequencies" but the same problems persisted on those same channels.
Once more I purged [Initialized] the program and then downloaded an app called: PSREdit100 [Demo version] and began to program the radio once more [using the first frequencies]. Interestingly enough, I discovered that this PSREdit-100 software didn't exhibit any of the same problems and though it is a little less User-Friendly. the app worked just fine.
I am confused because I use ARC-300 and ARC-500Pro for all my other scanners without any suggestion of an anomaly, yet this ARC-404 seems to baulk.
Got any suggestions?
I'd be happy to hear them. This WS-1025 is a sweet bedside radio which has 200 channels and also FM Radio bank.
Thanks in advance.
Vernon
Thanks in advance.
Vernon
