File
Since you have already been told about Freescan, here is a Freescan file for Hartsville. It also has Florence County since its only 9 miles se. I'm sure South Carolina scanner listeners can help you more but this should get you going. Since you have the cable, get the computer to accept the cable, Freescan you have to get the comport , but thats easy, Plug the cable into the computer and the scanner. From Freescan click the scanner tab, at the top. Control scanner, then click comport setup.then click start auto ands wait for Freescan to say which comport. Then click File, and select what ever file you want. Then upload to scanner and you wait. Then you are good to go.
