I'm sure this has been answered is probably obvious but I'm not finding it. Is there a way to add all the favorites lists from the radio into the tree on the left? I can only seem to download and edit one at a time. I would like to cut and paste a few DMR sites I initially saved into separate systems and lists to complete one large comprehensive system. Every time I select a new list to work with it erases the one previously shown in the tree to the left.
Also, I find that if you hover over the small DMR and TRBO blocks on the bottom the pop up box says (add a new P25 system), probably something they forgot to change when adding in DMR I assume.
