dleslie
I have a Uniden BCT15X and have an issue with the Freescan Site Setup screen. When I am populating the "State" field on that screen for [MOT2] and [EDC] sites, the program either doesn't save that field setting or doesn't reload it from the saved *.996 file. Before saving, I make sure that the site shows the state name, but when I reload the .996 file from memory, the state field is set to "Off". While I am working with the file onscreen and have the state field populated, I can upload to the scanner and the state name does populate in the scanner memory. The only interaction I can think of that might affect the state field is that I am using a GPS with the scanner, so I am also checking the "Use GPS with this site" field. Could this be negating the "State" selection field? Any insight will be appreciated. Dave
