The screen indicates that this is error number 2.
Click on the 2 and see what records are causing errors.
Sent from my LG-V410 using Tapatalk
Those usually turn out to be something like "WX settings missing" or "bandplan not found for system xxx", and don't normally shut down the wright to scanner.
I just uploaded this same file to a different BCD996P2 last week without any flaws. This is a new unit I got and is giving me trouble.
I've adjusted the baud rate, and that doesn't help. No matter how many or how few systems I select, it still times out and won't upload. I read that FAQ page and nothing there seems to fit my problem. Can anyone else help?
I've had this error a couple of times in the past.
You're eliminating the 'full memory' error by selecting erase all systems then send to the scanner.
If the file is unchanged since you used it on another similar (or same) model last week, then that would rule out too many TGID's in a trunked system, which is one source of this error.
What has happened to me in the past, especially when programming several different scanners, is that FreeSCAN will generate this error if it is "expecting" a different scanner. For example, say I loaded a file on one of my 396XT's. Then, tried to load, say, my BR330T. I might get this error because the software was expecting to see another 396XT to program. Try connecting the scanner to the pc with the cable, then instead of immediately loading, select the Auto, to make FreeSCAN "find" the port and identify which scanner to expect. This has worked for me in the past, and is worth a try.
