Win500 file save help
cadman99
Michigan
Hello to all, I am just starting to use win500 and would like assistance from those who are more knowledgeable in this program. I have the code entered, my account is active, and I can select my desired areas to download the data I would like. When I select save file, The application appears to save the file, however does not prompt for a file name or save location. Any help on this wold be greatly appreciated,
Thank you,
gmclam
Fair Oaks, CA
WIN500
I always use "save as" and name my files in a manner which ID what's in them. For example, I have D4_SF-2014-10-20.p500 which is a profile for San Francisco dated Oct 20 2014 which I store in virtual folder 4.
Sounds like you've got your profile built. The Save (or save as) functions save this to disc. You also need to upload it to your scanner.
cadman99
Michigan
Thank you for the quick reply. I was able to bet things going. Will update scanner when it arrives Monday.
