ARC536: Easy Fill
ol-redneck
Mount Ida, AR 71957
From the manual:
"Q. I Want to search a range of frequencies, how can I do that?
A. In ARC536 select Options _ Easy Fill. Now enter a start frequency and a step and ARC536 will fill a system with frequencies similar to a search in other scanners."
This is the only mention of "Easy Fill" that I can find... Where does this 'system' save?
ol-redneck
Mount Ida, AR 71957
Easy Fill (Search)
Just add a conventional system to the browser and then select Easyfill. Easyfill will then fill the system with the data you selected. Then select File _ Save System As to save.
Gommert
Butel Software
Thanks for the reply.
My Easy Fill screen does not look like the one in the manual. (attached)
I want to search for USFS freq. Someone suggested 160-174 mhz.
If I check 'Fill Series' it puts several hundred in. Is that what I want in order to search?
Also what does the 'Logging' feature do?
Sorry to be a bother but I'm sure others have this question. Thanks
  • easyfill.pdf
