Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #81 (permalink)
Old 05-06-2017, 2:23 AM
Please delete.
  #82 (permalink)
Old 06-06-2017, 11:01 AM
Still having this problem with Build 12. I found that I can avoid it by not allowing the program to write to the Config file. It still seems that this is not quite working the way it should.
Originally Posted by garys View Post
Using Version 2 Build 11 I've run into a problem. I updated a Favorites List and then uploaded it to the scanner. I opened the Edit window and checked only the Start Up Key I wanted to use for this FL. I then uploaded to the scanner. Upon restart I discovered that the FL would load on all Start Up Keys.
I rechecked the selection and uploaded again, thinking maybe I did something wrong. Same thing.
Am I missing something? Does anyone else have this problem?
Thanks.
  #83 (permalink)
Old 06-10-2017, 5:40 AM
Butelsoftware's Avatar
It doesn't seem to work when you are adding file. Modifying existing profile seems to work. I will look into this.
Gommert
Butel Software
>>> Visit us at the May 2017 Hamvention booth 3303 in building 3 ! <<<
http://www.butelsoftware.com
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
  #84 (permalink)
Old 06-10-2017, 4:08 PM
Thank you.
Gommert
Butel Software
  #85 (permalink)
Old 06-14-2017, 7:05 PM
Originally Posted by SurgePGH View Post
In sentinel you can but not in ARC536. This has led me to abandon ARC after I paid all of the money for it. It is very disappointing that the free software is out performing the paid software.
Have we found a solution for the lat long coordinates for location based scanning when using rectangles?
  #86 (permalink)
Old 06-18-2017, 9:37 AM
werinshades's Avatar
Gommert
Butel Software
I'm not sure if this is related, but unable to upload any changes on either my 436/536 with Build 12. Software will read from both scanners, but not write?
  #87 (permalink)
Old 06-18-2017, 10:34 AM
gonefishn1's Avatar
Try PROSCAN software with a free 30 day trial
BCD536HP x 2
  #88 (permalink)
Old 06-18-2017, 11:38 AM
There are no known issues uploading data.
Gommert
Butel Software
  #89 (permalink)
Old 06-22-2017, 2:31 PM
Gommert
Butel Software
No issues uploading or downloading in Sentinel. Uninstalled and reinstalled and unable to make any changes in either my 436 or 536. Not sure why this is happening since I updated to Build 12.
  #90 (permalink)
Old 06-22-2017, 4:06 PM
In build 12 support for PT and UBC3600 models was added. Nothing changed for the US models. Does the software detect the scanner ok? If you have multiple scanners you should only connect one scanner at a time.
Gommert
Butel Software
  #91 (permalink)
Old 06-22-2017, 4:08 PM
Gommert
Butel Software
Yes...one scanner at a time. Tried different Com Port and had same issue. Says it's detecting scanner, and is able to read it.
  #92 (permalink)
Old 06-23-2017, 2:29 AM
Com port? File transfer is via USB. See the V2 manual addendum for info how to use the new interface.
Gommert
Butel Software
  #93 (permalink)
Old 06-23-2017, 8:56 AM
Gommert
Butel Software
Sorry...my computer lingo is a little old. Yes...I tried different USB ports without luck. This morning, I just received Build 13. I never received any renewal notices, but noticed I started my subscription on 6-8-16. Is this the issue...I'm expired?
  #94 (permalink)
Old 06-23-2017, 10:36 AM
No, software does not expire nor does it require a subscription.
Gommert
Butel Software
  #95 (permalink)
Old 06-23-2017, 10:46 AM
Gommert
Butel Software
I'm at a loss. It was working well before Build 12 on both my 436/536. The only other thing I can think of is the SD card and the software are not getting along well with the last 2 builds? I've been using the Transcend 32 gb SD card and not having any issues in Sentinel. I'm using the cable supplied with the scanners and the software recognizes the scanner. Not sure where else to look?
  #96 (permalink)
Old 06-24-2017, 12:56 AM
jasejoSK's Avatar
Default Frequency input in build 13
Hello, greetings from Europe, Slovakia.
I'm running ARC536 v2.00 and just received build 13. I've got a problem that currently I am not able to input any frequency between 54 and 108 MHz into channel list.
If I try to input anything from 54.000 to 107.999 it switches to 0054.000 automaticly. I suspect it has somthing to do with regional setting (maybe number formats?) but I'm really not sure. As it is standard that comma (,) is used as a decimal separator in Europe, I always switch it to full stop (.) before working with ARC536 or Sentinel.
Thank you very much in advance for reply.
  #97 (permalink)
Old 06-24-2017, 8:52 AM
The software detects the scanner so there is no issue with the connection. Did you select the overwrite option?
Gommert
Butel Software
  #98 (permalink)
Old 06-24-2017, 8:54 AM
Gommert
Butel Software
Yes...the box is checked. Prior to Build 12, I used the software without issue.
  #99 (permalink)
Old 06-24-2017, 12:04 PM
WX4JCW's Avatar
Is there a change log for Build 13
Sent from my iPhone using Tapatalk Pro
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
  #100 (permalink)
Old 06-25-2017, 10:25 AM
Yes, change log is in the manual.
Gommert
Butel Software
