Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 04-19-2017, 7:28 PM
Tim's Avatar
Tim Tim is offline
Default BCD536HP & ARC536PRO Problems
Greetings...
I am trying to program the above radio with the ARCx36Pro and I am having problems right off the bat. I can't get the program to recognize the scanner at all. I am using the front port connected to the CPU via USB. I am told to select 'MASS STORAGE DEVICE' on the radio and then press yellow detect button. which I did and nothing happens. I tried downloading a new serial driver via device manager and I could not locate any sort of device on the update manager. Any advice or help would be appreciated.
I have the XT series radios and ARC so I know how to use it, but this one seems to be a bit different.
Tim
Old 04-19-2017, 8:33 PM
WX4JCW's Avatar
Connect the radio to USB then hit the E key , mass storage mode is not serial port driven it's is reading and writing to the ad card
Sent from my iPhone using Tapatalk Pro
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
Unication G4, BCD536HP, SDR
Old 04-19-2017, 9:17 PM
N9JIG's Avatar
Sheriff
For Virtual Control you need to be in Serial Mode (press the "." button).
For database and Favorites List Management you need to be in "Mass Storage" mode (press the "E" button)
Rich Carlson, N9JIG
Facts are facts but my opinions are my own and may not reflect those of whom I work for.
Old 04-19-2017, 10:37 PM
Tim's Avatar
Tim Tim is offline
So I am just trying to use the ARC to program the radio at this point for a family member. I have the radio in the USB Mass Storage mode no problem, but I can't get the ARC to detect the radio at all.
Old 04-19-2017, 11:03 PM
I take it that you are not seeing that yellow button disappear after a few moments and the BCD status button turn green?
Are you able to connect to the scanner using Sentinel? (If so, this would rule out issues with the cable or other bad connection issues).
Try connecting your scanner to your computer in Mass Storage Mode and going to your Windows Explorer. Do you see the scanner show up as a removable drive? (Another way of testing the scanner/computer connection).
Old 04-20-2017, 9:53 AM
Butelsoftware's Avatar
Mass storage does not require any drivers. Is the scanners SD card visible in Windows File Explorer?
Can you post the file drivetest.txt stored under My Documents\My Scanner Data Files\ARC536PRO
Gommert
Butel Software
>>> Visit us in november at Milipol in Paris ! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 04-20-2017, 6:30 PM
eaf1956's Avatar
Originally Posted by Tim View Post
Greetings...
Tim
Try running ARCx36 as administrator....
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2)
Ham Gear: Icom 7000, U82, V82, V8, IC 2820, MD2017, Vertex Standard EVX 539, MD 9600 and a YAESU FTM400DR
Old 04-22-2017, 4:03 PM
Tim's Avatar
Tim Tim is offline
I have been away from the computer for a few days. I will try those couple of things when I am by my mother's house again next weekend.
She said that she bought the radio new and I tried it on a few different computers. Perhaps it *is* the connection. I am just making sure, but you can't wireless use the ARC program...correct?
Tim
Old 04-22-2017, 10:20 PM
Tim
I'm pretty sure it has to be a wired connection.
