Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 05-16-2017, 11:10 AM
bravo14's Avatar
Question Have a few questions
I download the free trail a few days ago and I know you can't edit profile or custom search. I read the card from scanner to the arc536 basic and I edit some files to make threshold mode & level since you are able to chose more from it than sentinel. Now when I write back to scanner it turns on every quick keys. Is there a way to deselect what I don't want to scan even some sites I don't turn on either.
Radios IC-F43GT PSR-800 BCD536HP BCDSDS100
YouTube http://www.youtube.com/user/staugfl1991 (videos)
YouTube http://www.youtube.com/user/scannerfreak91 (Scanners)
Old 05-16-2017, 2:39 PM
Butelsoftware's Avatar
In the upload window double click the line of the file(s) you are uploading. Then you can enable/disable quickkeys.
Gommert
Butel Software
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 05-16-2017, 2:52 PM
bravo14's Avatar
Gommert
Butel Software
Before I write to scanner and I double click the line and the quick keys came up and I only see 1 is checked. When I upload it to scanner and still opens everything up. Do I hit the update button or send selected to scanner?
Old 05-17-2017, 11:47 AM
bravo14's Avatar
I got the quick keys to work. I'm having a problem when update it enables all departments and sites. How do I disable Depts & Sites I don't want active?
Old 07-20-2017, 2:36 PM
bravo14's Avatar
Gommert
Butel Software
I got it working sorry for the delay.
Old 07-29-2017, 9:26 PM
bravo14's Avatar
Default A-Z or Z-A
I wonder if I'm missing something. I'm currently on v2 b14 I am looking to put alpha tags in order like a-z or z-a or unit id in order a-z do I click on something to do that? Thanks.
Old 07-31-2017, 5:00 AM
Try double clicking the header of the column.
Gommert
Butel Software
Old 07-31-2017, 12:00 PM
bravo14's Avatar
I hit unit id and it doesn't go in order 0-60,000. When I hit the alpha tag it goes a-z or z-a.
Here is a sample
https://drive.google.com/file/d/0B-E...ew?usp=sharing
Old 07-31-2017, 1:22 PM
gonefishn1's Avatar
Try ProScan software. It works much better. Proscan has a free 30 day trial. I think Proscan is the best.
Uniden BCD436HP, BCD536HP
Old 07-31-2017, 2:07 PM
u2brent's Avatar
Or Sentinel will sort your uid's
Old 07-31-2017, 2:11 PM
bravo14's Avatar
I've been using Sentinel since day one. It's simple to use. I had too much trouble with DMR Conv. aduio I did some tests on Threshold(s) Use Manual and 2. Sentinel you can't go below 5. Also I like you can add the Nac for the P25 system in the Arc software.
Old 08-03-2017, 4:40 AM
Ok I see that the sort flag for the UID column is wrong. I will change it in the next build.
Gommert
Butel Software
Old 08-05-2017, 11:41 PM
bravo14's Avatar
Gommert
Butel Software
Okay thanks. I'm assuming you all working on where you can select or deselect the dept/sites?
Old 08-23-2017, 1:19 AM
MedicDavid78's Avatar
Default Arc-536 pro
I actually have a question too, since this thread is about questions... On the ARC-536 PRO software, I am just curious about 1 thing... When you are looking/adding a Trunking System, in my example a P25 system, under the General screen there is a thing that says ID: (Optional) and the numbers 7118 are for this system. Can you tell me what ID means on that page? It's not the System ID because that System ID is 1FC and it's not the Decimal conversion of 1FC cuz that is something else... Thanks! I have enclosed a picture attachment circled to show what I am asking about.
••David
Ham: WN4EMT, GMRS: WRAX515
Radios: XTS5000, XTL5000, XTS2500, HT1250, Baofeng UV-82, Anytone D868, CS-800D
Scanners: Uniden BCD536HP, Uniden BC246T
Old 08-23-2017, 9:13 AM
That is the Radioreference system ID. Double click the blue id tag to open the system in the RR database.
Gommert
Butel Software
Old 08-23-2017, 1:20 PM
Gommert
Butel Software
Beautiful! Thank you!
