Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 06-15-2017, 8:21 AM
Lwolf1313's Avatar
Default FreeScan
Does anyone know if FreeScan is still being updated? I was wondering if he added DMR programming capabilities to it?
Old 06-15-2017, 9:17 AM
marksmith's Avatar
DMR not added, but otherwise will support 996 p2 and 325p2
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
Old 06-15-2017, 9:50 AM
hiegtx's Avatar
Mentor
As Mark has already noted, FreeSCAN can program the 325P2 and 996P2, but does not support DMR. There have been no updates in quite a while, and it appears that none are forthcoming in the near term. The author has not been active in the forums, either here or on his own site, in quite a while.
As long as you are not dealing with DMR systems, the software still works just fine. If you will need DMR support, then look at either ARC-XT, or ProScan. I'm using ProScan for my 325P2, as I have several DMR systems of interest. ProScan also supports numerous Uniden models, and has logging/recording capability. ARC-XT only has logging/recording in the "Pro" version, which is priced higher than ProScan.
Steve
