Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 10-10-2017, 10:24 AM
Angry BCD996P2 upload problem
When I have loaded the program and setup the p25 system I want to scan I attempt to upload it to my scanner and I get the message (serial port not available or in use by other software) how do I fix this problem? thanks
Old 10-10-2017, 10:32 AM
iMONITOR's Avatar
What software are you using? Did you configure the port settings?
Old 10-10-2017, 10:50 AM
ProScan's Avatar
Exit the other program that's using the comm port.
Old 10-10-2017, 12:38 PM
I have not changed any port designations since I bought the Dell last January. Not sure why I would need to. All other programs recognize and us the usb's. I am using Butel XT for the programing.
Old 10-10-2017, 1:28 PM
rbrtklamp2's Avatar
Save your programming, turn the computer off, unplug the usb cable, restart the computer and plug the usb cable back in that should get you running again. Sometimes the com ports can get a little screwy on computer when working with radio software.
Sent from my SM-N910V using Tapatalk
Stop streaming public safety comms before encryption kills our hobby!
Old 10-10-2017, 3:26 PM
Thanks I finally stumbled on the problem. Under scanner I found communications and was able to assign the port.
