Old 04-29-2006, 09:20 AM
Default Not well-formed XML problem
Hi - wondering if the RR database maintenance watch this forum? Seem to have a problem when trying to import some data using Win97:
Code:
XML error detected: not well-formed (invalid token)
near:
<freq fid="124924" freq_out="4940.00000" freq_in="0.00000" desc="Police - MOTOMESH™" disp="" tone="" mode="5" class="RM" fcc="WQEK379"  updated="2006-03-03 13:23:36" />
while requesting URL:
http://www.radioreference.com/apps/xml1.1/?scid=1617
It looks like the (tm) after MOTOMESH is causing the problem? This is data for Kent County, MI using Win97 1.12. Can someone help??
Old 04-29-2006, 09:53 AM
MikeOxlong's Avatar
Send a message via AIM to MikeOxlong Send a message via MSN to MikeOxlong
I'm not even sure why this would be in the database?
Looks like a highspeed wireless system for police use. Not something that would be scannable.
Mike.
Old 04-29-2006, 10:21 AM
cristisphoto's Avatar
Default Heres what i found In the FCC's ULS
I searched the callsign that was in the "XML"....
WQEK379 GRAND RAPIDS POLICE DEPARTMENT COMMUNICATIONS BUREAU 0002731453 PA Active 02/18/2016
Is that where where you are?
Regards,
Crista
Hoo Ray Freedom !!!!
Old 04-29-2006, 10:25 AM
Default Your problems lol
Check that!!
I just tryed the RR Link..
it's actiually a restricted are for administrators...
I would post in support thread and ask them for permission.
That should ,(if they allow you to gan entry lol), cure your ills....
Old 04-29-2006, 10:47 AM
Yes, Grand Rapids.
I'm not worried so much about that particular frequency, but that the XML seems to be corrupted and is not allowing me to import data from RR into Win97...
Is there an admin that can either remove that frequency entry completely or remove the one character that seems to be causing the problem??
Old 04-29-2006, 10:49 AM
seamusg's Avatar
Originally Posted by cristisphoto
Check that!!
I tried the link and it's not restricted for administrators. The download feature is for donating members and he is a donating member.
Old 04-29-2006, 11:57 AM
this frequency is way out of the range that any scanner covers. There is no way you enter it. This freequency is 4900 MHz, or 4.9 GHz, not 49 MHz that you could enter into your scanner.
Old 04-29-2006, 12:03 PM
seamusg's Avatar
The real problem is that the XML error is blocking ANY download of Kent Co. MI, not just that one item.
The error is in this database under the city of Grand Rapids
http://www.radioreference.com/module...e=RR&ctid=1267
Old 04-29-2006, 01:13 PM
did you remove the offending frequency and then try to upload
Old 04-29-2006, 01:21 PM
seamusg's Avatar
What part of YOU CAN'T DOWNLOAD ANY OF KENT COUNTY DON'T YOU UNDERSTAND?
Old 04-29-2006, 01:50 PM
The error in the received XML kills the XML parser. There's no way to tell the RR DB to "send me all but this frequency", so he always receives the bad line. If the bad line is present, the XML parser halts.
The offending character must be removed from the DB, or RR's XML generator must be changed to 'escape' such characters.
Old 04-29-2006, 02:00 PM
Default Download Features and donating members...
HEy easy there lol
Not all of us are financially endowed.
Believe you me if I had the funds I would NOT hesitate to throw cash at Radioreference.
But thanks for the FYI though...
and technically its still considered restricted.
But only to NON donating members and not as i thought it was to other folks..
anyhow,
Signing off,
Crista
Old 04-30-2006, 12:37 AM
loumaag's Avatar
Moderator
Okay, the problem is not in the frequency. And I might add I have fixed this problem before in the past. I will fix it (again) in just a bit.
Lou Maag
Rules and Guidelines for Forum Post Content
Old 04-30-2006, 09:19 AM
Default thanks!
loumaag: web import is working now after that frequency was cleaned up.
seamusg and DonS: thanks for understanding what I was talking about!
Old 04-30-2006, 09:26 AM
seamusg's Avatar
Your Welcome. When you posted the trouble I tried it with Win96 and got the same trouble and knew it would blow up before you even got to select a frequency.
Old 04-30-2006, 10:51 AM
MikeOxlong's Avatar
I'm still not sure why the frequency is in the database?
It's not monitorable by hobbiests so it makes no sense to include it. Most scanners don't cover that range.
If we're going to start including this type of data, we might as well start listing all Wifi hotspots (closed or open).
Basically this frequency is used by public safety as a wireless broadband access point.
Here are the details on Motomesh:
http://www.motorola.com/mediacenter/...d=5341_5337_23
Mike.
Old 04-30-2006, 11:49 AM
seamusg's Avatar
I don't know either. If you try to download it with WIN96 it changes the frequency to 645.0325. Maybe you can talk to the Admin about it.
loumaag's Avatar
Moderator
Okay, just remember (as others have pointed out) that particular frequency will not work in your radio, so it makes no sense to import it. Also, if you run into this problem again, please post the error in the "Administration and Help" forum. The problem is not really in the software, but in the DB and I (and other DB Admins) are more likely to notice it faster there than here. Thanks for finding it. As a side note, I also found 4 more instances of that exact problem in the Michigan portion of the DB and corrected them all.
Lou Maag
Old 04-30-2006, 03:16 PM
There are plenty of frequencies and talkgroups in the database that are not generally "monitorable" in the usual sense, e.g., telemetry, encryption, etc. Every scanner has its own limitations in terms of what frequencies and modes it is capable of receiving and decoding. If a scanner does not support a frequency, then the scanner programming software that encounters such a frequency should prompt the user for action or at least skip over trying to load the frequency into the scanner. To the extent that a 4.9 GHz frequency in the database breaks scanner programming software, it is a bug in the scanner programming software. Furthermore, the database allows us to track identified frequencies even if they are not "monitorable" if for no other reason than knowing that we cannot monitor them.
-Eric
Similar Threads
Weird EDACS scanning problem c0wb0yup Alabama Radio Discussion Forum 1 02-20-2006 08:57 AM
396T EDACS Problem GTO_04 Uniden Scanners 19 12-29-2005 07:01 AM
BCD396T - MERA problem. Help? tdnuerf Uniden Scanners 1 09-26-2005 10:06 PM
Motorola Type II Scanning Problem w/ Pro-92 and 2067 TKennedy1975 Radio Shack Scanners 4 05-27-2005 08:44 AM
BC898T TV CH 8 Problem N9WP Uniden Scanners 4 11-30-2004 07:05 AM
