Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 02-06-2018, 2:25 PM
Default Monitor tab stuck on Mute
I am a new user of WIN500, I finally got the software communicating with my PRO-652 scanner and thought all was well. On the Monitor / Control Tab the MUTE field is in bold and I cannot find any way to change it. If I hit the WX control the MUTE goes away and I can hear audio from the scanner. I am not feeding the audio into my computer. I have the detailed help file for the software which is mentioned elsewhere in these forums. If I exit WIN500 and just use the scanner controls I still do not have audio except on the WX channels or if I enter a frequency into the scanner manually from without the computer, I do get audio.. Thank you for any help or suggestions.
Old 02-14-2018, 3:40 PM
Default Further Discussion
I have now downloaded a fresh copy of Win500 but still have the same problem (yes, I purchased the program originally). If I enter a trunked frequency manually into the scanner I will hear sound; but if I try to access that frequency through the Win500 program the MUTE will be active. I have studied the manuals again to see if I missed anything with no luck. I know that there are alternatives to WIN 500 but cannot afford to just spend money trying things to see if they work. Any recommendations? Thank you.
Old 02-14-2018, 5:27 PM
DJ11DLN's Avatar
Can you post a screen shot of what you are seeing? That will help people here help you figure the problem out.
If it looks stupid but it works...it ain't stupid.
Old 02-14-2018, 6:37 PM
Default Screenshot of Win500
Note “MUTE” in bold to the left of the orange window. When I manually enter a frequency that field is “grayed-out” and I can hear sound from the scanner. I cannot find anyway to change that field (clicking the mouse, etc.).
Old 02-14-2018, 7:48 PM
flythunderbird's Avatar
The 'mute' you're seeing is scanner audio status; it's not a button. As you noticed, it's grayed out because either 1)the scanner is receiving enough signal to un-mute the speaker or 2) the squelch is set to minimum, allowing audio to come through the speaker.
Glenn
"I got some radios ... I listen to some stuff ..."
Old 02-15-2018, 7:33 PM
Glenn, thank you for your response. OK, the software does not control the volume or mute functions. I was able to cause the MUTE to come on by playing with the squelch on manual searches. So, for some reason my scanner audio/squelch (RS Pro-652) is not working with programmed scanner frequencies. But it is working with manual entry scans or the preset Search function built-in to the scanner. Not sure how to proceed at this point; I could reset the scanner to the factory presets and re-build my file from Radio Reference/Win 500. This is assuming that something is messed-up internally.
Can anyone give me some input as to whether this is the best way to proceed? Thanks again to all looking at this, Reid
