Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 03-09-2018, 8:27 PM
Default Big Problem
I'm using Proscan software to program my scanner and when I disconnect the cable the scanner shuts off and won't start up. when i connect back up to the computer it works again. Can't figure it out. can anyone help
Old 03-09-2018, 8:46 PM
iMONITOR's Avatar
Question
What scanner? Serial port, or USB port? Are you shutting down the software before disconnecting the scanner?
Old 03-09-2018, 9:31 PM
I figured it out. I had to reset
Old 03-09-2018, 9:32 PM
KC1UA's Avatar
Scan New England Guru
Sounds like a portable scanner that is powered by the USB connection and either has dead or no batteries installed. Just taking a guess based on the vague info.
Scott - Scan New England Webmaster
http://www.scan-ne.net
Formerly known as "scancapecod" in this neck of the woods...
Radio Reference MA, RI, & CT Database Admin
