Couple questions regarding the ARC536Pro software:
1. When you right click on a department the last option "Sort" is check marked but I am not able to un-select it?
2. When using the option to "Center Justify" systems, it appears the software takes into account the spaces before the text that it adds to sort by, so using the "Center Justify" feature basically prevents the sort feature from working properly. The center justify makes the reading of the display much easier but makes it impossible find entries easily since the sorting is no longer in alphabetical order.
Hopefully I am just missing something
