Have any of you had any luck importing files from the arc xt pro to arc 536 pro?
Here is what I have
arc xt pro is version 2.1 build 5
arc 536 pro is version 2.1 build 6 beta
files in xt pro are .rsf
files in 536 pro are .hpd
when I open 536 pro, select import and select arc xt files, I can select file from list and hit open.
Under the favorite browser I see unsaved system appear and there is no data to look at.
If I select 396/996 file, I see no files, but use the drop down and select all files and then the names show up. I again can select a file name and hit open and then see " file not compatible or saved in newer format".
Anyone else seeing this, or if you are able to import, if so what are you seeing to make it work?
Here is what I have
