Closed Thread
Old 05-16-2006, 09:43 AM
Exclamation BC-796 reallocating memory
my questions is it possible to change memory such as tg ids from 100 to 100+, my county has 156 tg just for fire side and pd has even more, my reasoning for this so that i can have it set per area.
Firemen_2709
Old 05-16-2006, 10:35 AM
seamusg's Avatar
It can be done with computer software where the computer displays the TG ID insted of the radio, but I don't know of any available at this time.
Old 05-16-2006, 01:31 PM
AZScanner's Avatar
Location: Somewhere in this room. Right now, you're very cold.
What type of system?
If it's an EDACS system, you can use AFS to hold a bajillion of 'em.
For example, let's say you want to monitor these talkgroups:
01-011 to 01-019
If you store 01-01- as a talkgroup ID you'll catch all 9 of these under just one channel entry. You can even store 01---- as a talkgroup and get all talkgroups that start with 01- with just one channel. It's a really cool feature!
Unfortunately, there's no similar option for Moto systems. That'd be sweet if it there was (here our fire dept digital simulcast TGID's are all 17xx. - I could catch them all in one channel which would be nice.)
Another option might be to use Trunker or Unitrunker... then you can monitor hundreds of talkgroups if you wish, but only while tethered to your computer. Not sure if Unitrunker follows voice traffic yet but I think Trunker can now use just one scanner - if not it would be an easy mod to the source code.... ahh now I'm wandering... nevermind.
-AZ
Tempe/Chandler live feed: http://www.scanarizona.us
Have you been booted or ticketed by Arizona Parking Solutions? If so, read this.
http://forums.vwvortex.com/zerothread?id=3880087
Old 05-16-2006, 02:48 PM
nosoup4u's Avatar
Send a message via AIM to nosoup4u Send a message via Yahoo to nosoup4u
Actually there is a way to do it on a motorola system (only for type 2 systems). What you need to do is setup the system as a type one, and depending on which size code you use, you will be able to hear all the talkgroups in a particular range. When the NJ State Police was a hybrid system, (Size S-13 at Blocks 0 & 4), you could hear the type 2 talkgroups on 000-13 and 400-12.
John - KC2KZZ
http://wc2em.net/scanner
http://kc2kzz.blogspot.com/
BCD396XT, BCD996T & BCT15
Saber II (VHF), HT1000 (UHF), Astro Saber III (800)
Old 05-16-2006, 04:40 PM
Wiki Admin
Both IDTracker (which is free) and the Radio Manager 2004/Trunk Manager (you would need both if you go this way) could do this. In both cases, the lookups are done with dedicated PC files, not scan lists as defined in the radio.
You can find both of these packages linked here;
http://wiki.radioreference.com/index.php/BC796D
73s Mike
Old 05-17-2006, 09:35 AM
Question BC-796 Reallocating memory
First, thanks for all the responses,
The systems is Motorola, Type 2, Smartzone, uhf system, i'm currently using unitrunker, it's a very good program, but i would like to set the796 so that bank one, has 11 sets of 16 tgs. All motorola radio used in the county are 16 channls and an unknown number of banks, I am only looking to change the memory in the radio. I'm not even sure that it is possible to do. The unitrunker radio that is used has not digital software or hardware(Pro-2067)
Here is the link to the system that I'm monitoring with unitrunker and BC-796:
http://www.radioreference.com/module...TRSDB&sid=1320
Firemen_2709
Old 05-17-2006, 09:59 AM
W4KRR's Avatar
If you're asking about increasing the memory capacity of the radio, then no, it's not possible, not without changing some internal parts.
Ken
Old 05-17-2006, 10:24 AM
UPMan's Avatar
Uniden Product Manager
And rewriting the firmware.
Got a question? Ask it in a public forum for faster response.
My solar power station
Old 05-23-2006, 09:38 AM
I guess that i'm not stating my question correctly:
you know that the 996 has banks that you set from scratch, all i'm looking to do is change bank one from 100 freq channels and only use 15 from the bank and use the other 85 for tg's so that the quantity would be 185 tg and only 15 freq channels. is that a little more clearer
Firemen_2709
Old 05-23-2006, 09:47 AM
UPMan's Avatar
The memory configuration of the BC796D (as well as any other banked scanner) cannot be changed. IIWII.
Old 05-23-2006, 09:51 AM
h8tdigitalradio's Avatar
Your position is quite CLEAR
Again, as previously stated, what you wish to do is NOT POSSIBLE using the BC796D. The Banks are 100 Channels FIXED. TG's per Bank are 100 FIXED. The BC796D has no Dynamic Memory Structure. Simply program 2 banks for the 185 TG's you wish to program.
You cannot make Channels or TG's per bank any size you wish.
73
Dave AKA The Tripzter
©MMIV-MMIX by "The Worst of Tripzter®" All rights reserved.
Old 05-23-2006, 12:08 PM
loumaag's Avatar
Moderator
Asked, answered, closed.
Lou Maag
Rules and Guidelines for Forum Post Content
Closed Thread
Similar Threads
Question About Dynamic Memory roadman1977 Uniden Scanners 5 04-10-2006 08:48 PM
BCD396T: Memory Capacity Glitch? bacon Uniden Scanners 22 03-23-2006 04:09 AM
Future scanners using SD memory cards? W4KRR General Scanning Forum 7 06-16-2005 11:40 PM
The Uniden 246T: The next paradigm shift in our hobby... br0adband Uniden Scanners 3 04-29-2005 09:03 PM
BC246T Memory usage System and Groups Pro-95 Uniden Scanners 8 04-10-2005 08:40 PM
