Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 12-02-2018, 8:11 PM
Arrow ProScan Question
Dumb question. To assign a Quick Key to a system, using Database/QuickKeys/Search Keys, you toggle it on using the grid and type in the description such as Aircraft. After that, if you change your mind, you can set the quick key to 'not assigned', but you can't delete the old quick key description.
Old 12-06-2018, 7:38 PM
In my case, you must check "systems" and unset the QK, then check "custom searches" and unset any QK. Once there is no QK assignment anywhere in the database, the QK tab QuickKeys/Search Keys will reset itself to not assigned.
FF
