Old 05-23-2006, 09:26 AM
lsr1428's Avatar
Default arc 246 software issue
hi the problem i'm having is when i try to downloaded the new edac's system for ingham county in michigan threw the internet option on the 246 software they all come up but when i open it up in the software it shows it bieng a convential system and has now freq. afs, there all blank when the system first came out i had no problems with this issue and was able to get it to work but since they updated with afs and other things with system i have this problem i hope i explained it ok thanks
Old 05-23-2006, 10:34 PM
Al42's Avatar
If you select trunked systems it will download the Ingham County EDACS system. I downloaded all the groups. The only problem I see is that there are a lot of missing talkgroups.
Suffolk County, NY PD live stream
and the files you'll need to do it yourself: http://www.webdingers.com/scanner.html
Winamp connection: suffolkscanner.redirectme.net:8000/stream
Old 05-23-2006, 11:02 PM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
This system imports fine here, but as Al mentioned a lot of id's are not entered in the database yet (only the name tag) so the software clears them automatically since 00-000 is not a valid id.
Gommert
www.butelsoftware.com
http://www.butelsoftware.com
Become a BuTel Software affiliate! Check our website for details.
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 05-23-2006, 11:03 PM
Gommert
Old 05-24-2006, 09:19 AM
lsr1428's Avatar
how about when i down load the edac's for ingham county, michigan and open it up it coms in as a convential system and not edac's wide and like i said it won't show any lcn channels when th esystem first came out on r/r i had know problem but now that i want to update it i not getting any inf accept the the name of the channel thanks for the help
Old 05-24-2006, 04:50 PM
Al42's Avatar
If you're not getting the control channels you're evidently doing something wrong, but you will get only "the name of the channel" for most talkgroups, since that's all there is in the database for a lot of them.
Old 05-27-2006, 01:26 AM
Hello.Please bear with me if this question has been addressed before.I just bought a BC 246T.I am going to buy Butel software from Scanner Master.I noticed and downloaded a free clone program just in case I really screw up. Is this compatible with firmware 2.05?Thank you.
Old 05-27-2006, 11:03 PM
Al42's Avatar
The clone program stands alone - it doesn't depend on firmware version, software version or anything else. But, if the 246 is like the 396 (I don't know, but the manual should have the information), you can reset it to the original systems (or to totally blank - your choice when you reset).
And ARC246 can also "clone" (back up) the scanner.
Old 05-27-2006, 11:43 PM
Thank you for your reply Al42.The wording at the site was a bit confusing.Thank you again for clearing up the confusion.
Similar Threads
>> Various Scanner Software << jerneedog General Scanning Forum 47 03-11-2007 03:22 PM
R75 Software Halfpint ICOM Receivers 9 04-21-2005 01:23 AM
BuTel software releases free software for Uniden SC230 Butelsoftware Scanner Programming Software 0 03-14-2005 11:27 AM
FYI: BC796D SOFTWARE DEFICIENCY W4UVV Uniden Scanners 0 11-10-2004 11:58 AM
FYI: BC796D SOFTWARE DEFICIENCY W4UVV Uniden Scanners 0 11-10-2004 11:57 AM
