Originally Posted by UPMan
Each USB jack on your PC will typically map the serial device to a different COM port. As mentioned above, you can see what the current mapping is by looking in the device manager.
A little trick, Paul. If you plug the adapter into a USB port and choose the COM port number (in device manager), you can choose the same COM port number for all your USB ports for that adpter. Windows will warn you that the port is in use. Sure it's in use - by that adapter when it's plugged into another USB port.
This way the software will work with no change regardless of where you connect the scanner.
