Old 06-17-2006, 03:48 PM
Default Com Port Splitteer
Someone in this forum had talked about a com port spitter he uses. Anyone have details on this?
Old 06-17-2006, 04:06 PM
K8PBX's Avatar
Are you talking about a comm port switch?
Since I only have a single serial port on my PC, I use a 4 port DB-9 (ABCD) switch to control multiple scanners. It's a bit of a cabling frenzy, but works just fine. Here's a link so you can see what it looks like: 4 Port Switch also one on eBay HERE
Steve
Old 06-17-2006, 04:13 PM
This was the post: Is there any chance of having support for more than 10 serial ports? I run serial splitting software/driver so that i can keep the feed up while making quick changes with the ARC250.
Old 06-17-2006, 05:01 PM
If you mean a switch box that will connect your single PC com port to 10 external devices then it's unlikely to be a common item. There were 2 and 8-postion versionsof th switch boxes available years ago but the 8-port ones seem rare now. I put a pci serial card in each of my "radio" PCs so they each have 9 actual com ports available. I still use a couple of the switch boxes to swap between some other lesser used kit.
Old 06-17-2006, 06:02 PM
Send a message via AIM to mikea7531
I was the one that made the comment. This is what i'm using http://www.eltima.com/products/serialsplitter/ i'm still using the free trial, i'm still trying to find a freeware version if one exists.
-Mike
KC2SHG
Old 06-18-2006, 01:25 AM
RISC777's Avatar
If you're looking at a hardware solution, there are cards that will provide up to 16 serial ports on that one card.
Alternative is to daisy chain external switch boxes, but that could be a giant pain in the neck not to count the cost of serial cables or/and gender benders.
Doesn't expecting the unexpected make the unexpected expected?
Similar Threads
Port Aransas / Mustang Island kkn50 Texas Radio Discussion Forum 5 07-21-2009 04:45 PM
Port Hope Fleetnet Troubles hastingsmedic Eastern Canada Radio Discussion Forum 7 05-17-2006 07:46 AM
Remote control of BC-250d over IP? Liverdog Scanner Programming Software 31 02-12-2006 10:34 PM
Serial Port to USB problem...... Towpro Radio Shack Scanners 10 01-23-2006 03:36 PM
Port Police and 453.575 TinEar Maryland Radio Discussion Forum 7 10-21-2004 09:51 AM
