Old 06-24-2006, 01:02 PM
Default ID Tracker II ???
I just ordered a BCD996T. After looking at the software protocol for this scanner, I have decided not to include support for this scanner in ID Tracker but attempt developing ID Tracker II to support this new generation of scanner.
I plan on keeping much the same format and capabilities as ID Tracker but there will need to be some changes made. Initially, only Serial Port support will be available since this will be the quickest way to get things started. I may add USB support in the future.
Any thoughts on this?
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Old 06-24-2006, 01:15 PM
brandon's Avatar
Sounds like a great plan. I use your software with my older Unidens for logging unknown EDACS talkgroups. Is it also possible to add BC246T support? I would love to dedicate that scanner to it and for trunker.
Old 06-24-2006, 03:36 PM
Brandon,
It's possible to add support for the 246T. The protocols are very similar so once I figure out the 996 then adding the 246T should not be much of a problem. I will need a tester with a 246T.
Baton Rouge, LA
Similar Threads
WTB: Motorola 3000R Type II 800mhz markmc55 Old Classifieds Archives 1 06-05-2006 05:36 PM
ID Tracker, update released! MacombMonitor Scanner Programming Software 19 02-06-2006 06:52 PM
ID Tracker for 2055? RocketMan1 Scanner Programming Software 2 01-07-2006 01:09 PM
ID Tracker n8chb Motorola Forum 2 01-18-2005 03:14 PM
ID Tracker with BC245XLT greenthumb Trunking Control Channel Decoding 5 08-25-2004 12:39 AM
