Win97 HELP!!!!
Ok guys. I have just recently bought my copy of Win97, and installed it successfully.
I also went to RadioShack and picked up my Pro-97 programming cable with software. I assume I installed the driver for the USB successfully also, because during the install, my computer showed me a couple files that were "installed".
Anxious to try Win97, I loaded up a couple local frequencies and saved the Win97 file. I plugged up the cable to my USB, and then to my scanner.
The scanner display now reads "**CLONE MODE** Press UP to send Remove cable to exit."
Ok, So I click on "Scanner" and then "Upload to scanner" on the Win97 program up at the top. A box pops up, that says "Writing to Scanner". Inside the box, it displays "Initializing" for a second, and then "Writing Data" for a second.
Then, another box pops up that reads "Expected to read back the data we just wrote - This failed, make sure the COM port is connected" or something..
What is going wrong? Have I not installed the USB drivers right? Please HELP!!
Realistic Pro-57 (10 channel workhorse)
GRE PSR-500
