For Windows XP, go to the "control panel" then "system" (you may have to switch to classic view) then click on the "harware" tab. Click the "device manager" button the the plus sign next to ports. The port you want to select will be next to "USB Serial Port"
If you are using Win97 you need to change the srial port under the "configuration"menu.
Hope this helps!
Pro-96
Pro-97
Pro-90
BC-260
Plectron x 2
