Old 10-23-2006, 08:58 AM
Default win 96
When I download freq. I have more that 29 Alpha tags. but on the software there is only room for 29. So is 29 the max I can use or does it drop one and add one when I import the file.
Old 10-23-2006, 10:09 AM
W5JSS's Avatar
I think you mean talkgroups.
To the left of the talkgroup "box", you will see "bullets' 0 - 4, and each of those has a check-box beside it.
If you select the next "bullet", you will see the rest of the talkgroup ids (and alpha-tags where applicable) that Win96 has imported.
The check-box turns that groups of id's on and off.
Old 10-23-2006, 04:56 PM
Thanks I am still learning this software (Win96)
Old 11-04-2006, 05:38 PM
akuter's Avatar
Got this error trying to web import.
XML error detected: junk document element
near:
<br /><b>
while requesting URL:
http://radioreference.com/apps/zmll.l/?ctid=1618
Similar Threads
PRO 96 / Win 96 Programming Help rqueen2229 Radio Shack Scanners 33 04-11-2009 06:47 PM
win 96 problem scannermaniac Scanner Programming Software 3 10-08-2006 07:50 AM
Philadelphia Police / Fire Win 96 wirelesscop Pennsylvania Radio Discussion Forum 7 07-31-2006 08:18 AM
Help with win 96 program setting the steps and wc8i Scanner Programming Software 0 07-02-2006 09:09 AM
Win 96 Michigan Setup Help jcrincon Michigan Radio Discussion Forum 2 06-11-2006 08:21 AM
