| Scanner Programming Software This is the place to discuss scanner programming and control software. |
10-28-2006, 12:52 PM
ID Tracker II Released
ID Tracker II has been officially released. ID Tracker II basically
supports all of the features of the original ID Tracker with the following
exceptions:
- Supports the BCD396T and BCD996T scanners only.
- Supports the concept of dynamic system allocation and the use of systems
instead of banks.
- Channel descriptions are automatically retrieved from the scanner.
See version history for other information:
http://bellsouthpwp.net/k/d/kd5eis/I...rIIVersion.htm
ID Tracker and ID Tracker II can be found here:
http://bellsouthpwp.net/k/d/kd5eis/I.../IDTracker.htm
10-29-2006, 12:15 PM
Moderator
Dave,
Thanks for your dedication to the hobby and this enhancement specifically.
10-29-2006, 12:51 PM
Yes, great program Dave, thank you!
10-29-2006, 01:00 PM
All I am getting is this, when I try and click on any of your links.
Access Denied. Bandwidth limit exceeded.
10-29-2006, 01:31 PM
10-29-2006, 05:48 PM
Originally Posted by DaveIN
Thanks for the link.
Sorry about that. My site always takes a hit when I make a new release. The effect is usually temporary and last a few days at most.
10-30-2006, 07:15 PM
Yup, I kind of figured that is wha happened.
10-31-2006, 03:52 PM
Does ID Tracker II recognize PCMIA serial cards? My BCD396T is plugged into COMM 4.
I've got it working fine with ARC396 but ID Tracker II shows "Initialization Failed" error (NOT running concurrently) at any baud rate.
Help!
Andy
11-01-2006, 09:51 AM
Originally Posted by Boomeranger
Help!
Problem solved. The comm port and the scanners baud rate were different. OOPS!
All is working fine.
Sorry about that.
Andy
11-03-2006, 01:08 AM
Sorry about that.
Andy
I was optimistic about seeing this post. However, I still get the same error message, that being "Initialization Failed".
My baud rate and port are the same as are with ARC396.
Any ideas?
11-03-2006, 08:44 AM
Any ideas?
Make sure you're using the ID Tracker II software specifically designed for the BC[39]96T scanners NOT the ID Tracker software.
I made this mistake myself early on!
Good luck,
Andy
11-03-2006, 08:56 PM
Good luck,
Andy
Thought I did - tried again just to make sure. "Initialization failed".
Edit: Scratch that. If I told you what the problem was, you wouldn't respect me in the morning...
11-04-2006, 04:19 AM
C'mon... for the benefit of others, fess up!!!
Andy
11-04-2006, 09:50 PM
Andy
Well, if I have to....
Unlike the free Uniden software, ARC396 and Advanced Virtual Control, ID Tracker needs to have "THE SCANNER TURNED ON" when starting the program.
I fall on my sword with this one.
11-05-2006, 01:17 PM
Moderator
