Old 11-02-2006, 02:20 AM
Thumbs up Bct15 Programming
Help!
I Am New To Scanners And Need To Know The Easiest Way To Program My Bct15. I Am Not Sure What Type Of Systems The Local Pd And Chp Are Using And Right Now Get Very Very Little Pick Up As The Scanner Came Programed. I Live In The Centeral Valley Of California And Do A Great Deal Of Driving Up And Down The State So Chp Is The Main Choice To Scan. Also What Is The Best Roof Mount Mobile Antenna?
Any Help Would Be Great
Hang Loose
Bigbaboona
Also Can CB Frequencies Be Added/tuned Into A Magnum S9 Radio?
Any Links Or Experts?
Old 11-02-2006, 06:32 AM
Wiki Admin
OK first things first - click on the 'Database' link at the blue toolbar, select your state and check out what frequencies are used in your area of California. If you see output and input frequencies on the listings, concentrate on the outputs - you would need to be quite close to hear any of the input frequencies.
If any of the listings mentions 'Motorola' or 'EDACS' - don't panic - these are types of trunking systems. Trunking is a method where mutliple users can share the same set of frequencies, all without walking on top of one another. We have several articles linked in our Wiki section that can help explain all that...
http://wiki.radioreference.com/index.php/Trunking
(just single click on the blue text - you'll be taken there)
Now onto your BCT15 - there are several new concepts to this generation of scanners, and you need to get a handle on understanding them. Uniden's Paul Opitz wrote a nice article on the subject here...
http://www.grove-ent.com/SCANNERPROGRAMMING.htm
I would start by reading the above, then go to the California forum and see if folks have files for your area (quite likely they do). You will need software to program the BCT15, if you're not doing it by hand - and there are a couple of packages for doing just that - and they are linked at the bottom of...
http://wiki.radioreference.com/index.php/BCT15
The UASD (Uniden Advanced System Director) and BuTel's ARC15 are by far the most popular, but Scan Control works with the BCT15, too. Let what you find in the California forum guide what software you purchase.
73s Mike
Similar Threads
Programming Input Frequencies on BCT15, et al. Dave_D Uniden Scanners 0 08-14-2006 04:48 PM
BCT7 and BCT15 JackSmith102 Uniden Scanners 4 08-07-2006 02:53 PM
Programming your Uniden scanner for Bell Mobility Radio's Fleetnet system MikeOxlong Eastern Canada Radio Discussion Forum 1 07-18-2006 11:01 AM
Programming software to control a scanner Gilligan Scanner Programming Software 5 01-19-2006 11:24 PM
2096 Programming pcfn360 Radio Shack Scanners 0 11-24-2005 08:09 AM
