Closed Thread
Old 11-04-2006, 07:09 PM
twowayradiomouse's Avatar
Question WIN 96 download problem
Hi Guys... long time no talk to...
My Thornton PD freqs have stopped working so I went into my win 96 to re-load them. However I am getting this error:
XML error detected: junk after document element
near:
<br />
<b>
while requesting URL:
http://www.radioreference.com/apps/xml1.1/?ctid=241
It also says to copy this error and post it here so it can be fixed in the RR Database.
I am clueless as usual.
Any help with this would be very helpful.
Thanks........ Mic
"The sum of the square roots of any two sides of an isosceles triangle is equal to the square root of the remaining side.
Oh, joy! Rapture! I've got a brain! How can I ever thank you enough?"
Old 11-04-2006, 10:54 PM
ScanDaBands's Avatar
Send a message via Yahoo to ScanDaBands
Originally Posted by twowayradiomouse
XML error
Thanks........ Mic
Went through the SAME THING!!
the above NEEDS TO READ this
instead of the 1.1
Old 11-05-2006, 12:19 AM
actually hey I just tried it and it's doing the same thing , no matter what , must be an RR database problem.... ?????????????????????????????????????????????????? ????????
Old 11-05-2006, 03:43 AM
Seņor Member
Try it again.
http://www.radioreference.com/apps/xml/?ctid=241
Old 11-05-2006, 08:57 AM
fmon's Avatar
It fails on all Win96 & Win97 imports. ARC works ok so I suspect Don is doing some changes since starting the 180 day temporary use of Winxx. However, it is now nearly 26 hours since the original post by Mic.
Frank
RR Wiki Programming Shortcuts
Old 11-05-2006, 09:18 AM
Dubbin's Avatar
ARC and Win96 is not working for me. There must be more to it then Don doing something.
Dwayne
My Scanner Feed
fmon's Avatar
Default Gulp
Ah, after posting, Jambo found the solution in the Win97 thread early this am. Remove 1.1, which is Rick's suggestion. <Gulp> Sorry bout that Rick.
Frank
Old 11-05-2006, 09:20 AM
Dubbin's Avatar
That seems to only work for trunked systems.
Dwayne
My Scanner Feed
Old 11-05-2006, 09:29 AM
fmon's Avatar
Yup, you're correct. ARC only works on Trunked systems also. I can get into Conventional, but nothing is listed under the <Select> dialog for import.
Frank
Old 11-05-2006, 10:28 AM
I saw the problem yesterday (and confirmed it in a web browser), but both trunked and conventional seem to be working now, using the 1.1 version of the URL.
EDIT: Lindsay posted a reply to a similar thread in the Administration forum at 0641 PST this morning, saying it should be working now. Apparently, he fixed something.
Old 11-05-2006, 01:35 PM
loumaag's Avatar
Moderator
instead of the 1.1
This is never a good idea. The access via "\xml\..." as opposed to the correct "\xml1.1\..." is only there for compatibility with older software that was written (and not updated) when the Web Service specification changed.
As pointed out in other threads, this was a RR Site problem and has been resolved, so this thread is closed.
Lou Maag
Rules and Guidelines for Forum Post Content
Closed Thread
Similar Threads
Pro-96 Strange Antenna Problem SAR2401 Antennas and Coax Forum 3 03-11-2008 06:50 AM
Constant problem recieving priority calls on Motorola system, Im begging for Help! CapitalPunishment General Scanning Forum 30 02-20-2006 07:30 PM
Weird EDACS scanning problem c0wb0yup Alabama Radio Discussion Forum 1 02-20-2006 09:57 AM
Help With Trunking Problem, Please! njman Harris / MA/COM / GE / Ericsson Forum 1 09-10-2004 10:11 PM
Pro-95 Trunking Problem... erikTromatowski Trunking Forum 2 07-12-2004 08:11 PM
