Originally Posted by capt512
Well I bought the DB9 to USB serial adapter, and it connects and shows connected, but the e-scanner software from uniden does not detect the scanner...is it just the software?
Yea probably your COM PORT go to start menu , control panel , system , hardware , com port and see what it set it up for (what number com port) . Then check it in e-scanner config to make sure they match! And also make sure they are both set for the same BAUD RATE!
