Old 11-09-2006, 02:26 PM
kb0nly's Avatar
Default Win97 Import .CSV
Anyone know how to make this work? I got .csv files from RR, i downloaded all the counties i wanted to have in the scanner a while back when i was a paid member and saved them all for future use.
I opened Win97, selected Import, and then selected the .csv file and then nothing happens as far as i can tell. There is nothing in the channel list, all blank.
Does it import the frequencies directly to the channel list or is there something else i have to do here?
Also, does it also import the channel name or do i still have to type in a alpha channel name for each channel it imports??
Old 11-09-2006, 02:30 PM
Win97 only imports CSV files that match its own format. To see an example of this format, export a CSV file from Win97 and look at it in a text editor (e.g. Notepad).
For a detailed specification of the CSV format, look at http://www.starrsoft.com/software/CSVSpec.txt
Similar Threads
Win97 error trying to import FL conventional edweirdFL System-wide Administration 2 11-05-2006 11:42 PM
Win97 Web Import Not Working berean_315 Scanner Programming Software 4 07-09-2006 01:41 AM
XML Errors when trying to import Parma, OH in Win97 JimRichmond System-wide Administration 2 02-13-2006 02:57 PM
Win97 Web Import and talk groups text rsovitzky Scanner Programming Software 6 02-08-2006 02:16 PM
WIN97 WEB Import Problem scsscanner System-wide Administration 1 02-01-2006 12:05 AM
