Old 11-10-2006, 05:10 PM
Question WIN97 Web Import Works?
I just downloaded WIN97 (trial) and tried it out. Everything seems to work OK except the Web Import. I requested the following conventional frequency information:
Country -- United States State -- California
Agency -- California Department of Forestry and Fire.
WIN97 came back with a set of categories; I checked all the boxes -- then what?
It wrote a dataset to my hard drive called xmldump.txt which had all the frequency data in it but was not in a format I could import to WIN97. What do I have to do to get the data into WIN97?
I feel stupid, but I ran out of things to try. The HELP doesn't.
Old 11-10-2006, 05:51 PM
W5JSS's Avatar
After you checked the boxes, did you click "IMPORT SELECTED CHANNELS" at the bottom of the window?
Old 11-10-2006, 06:06 PM
Smile WIN97 Web Import Works
That was it. Thanks. My window didn't have a bottom. My screen resolution was too low. When I set it to high resolution and I could see the entire screen, sure enough, there was an 'Import Frequencies" button. I never would have figured that out -- many thanks.
Similar Threads
Win97 Import .CSV kb0nly Scanner Programming Software 1 11-09-2006 02:30 PM
Win97 Web Import XML Error pddoty System-wide Administration 0 11-04-2006 04:51 PM
Win97 Web Import Not Working berean_315 Scanner Programming Software 4 07-09-2006 01:41 AM
Not seeing all freqs during web import (Win96) dren Scanner Programming Software 3 06-29-2006 11:07 PM
XML Errors when trying to import Parma, OH in Win97 JimRichmond System-wide Administration 2 02-13-2006 02:57 PM
