Old 11-15-2006, 04:49 PM
datainmotion's Avatar
Default ARC996 Hangs
Intermittantly and with no warning, ARC996 will stop running. This only seems to happen with the virtual control running. I have to restart the laptop and ARC software to get it running again. Win XP Event Viewer reports App Hang on ARC996 whenever this happens. In addition when ARC996.exe hangs the memory it ties up goes up abot 10x what it normally runs at.
Itronix GoBook III running WinXP SP2
2048MB RAM
Denver International Airport - Public Safety Online Scanner
Travelling to or through Colorado? Click here
Old 11-16-2006, 06:07 AM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
Are you doing recording? If so make sure the laptop does not go in powersave mode.
Gommert
www.butelsoftware.com
http://www.butelsoftware.com
Become a BuTel Software affiliate! Check our website for details.
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 11-16-2006, 01:21 PM
mike_s104's Avatar
2048MB RAM
don't get me wrong, I love the software (I have ARC396 and I think the ARC996 is maybe close to it). there are a few issues with it. try making a shortcut to your desktop (if not already there), right click on it and select the Compatibility Mode tab. check the first box and select Windows 98/Windows ME setting and click Apply then OK. this helped me out a lot and has made it a little more stable.
Old 11-17-2006, 12:45 AM
Gommert
No recording. Just monitoring.
Old 11-17-2006, 12:48 AM
Other items I forgot in my first post:
This is a straight serial cable connection - no USB.
This unit is mounted in my truck.
I had the exact same set-up with my BC780 / ARC780 on the same laptop and never had a problem.
Old 11-17-2006, 11:44 AM
Are there any errors shown?
Gommert
Old 11-17-2006, 04:58 PM
Only when I go into the Win XP Event Viewer "App Hang on ARC996.exe". There are no on-screen errors, if that is what you are asking.
After further research, I have also discovered that when the Virtual Control is running, it will prevent other apps from running correctly - one such app is Sony's Sonic Stage (media player). It's GUI will start, but it will not function at all.
If I start the Sony app first it is fine. If I start ARC996 first and the Virtual Control - no joy on Sony as stated above.
Old 11-20-2006, 05:56 AM
Try installing new copies of both programs (after uninstalling them). Maybe a system file that they share is corrupt and a re-installation should take care of that.
Gommert
Similar Threads
Moving ARC246 Files to ARC996? WB2UZR Scanner Programming Software 4 10-25-2006 12:25 AM
ARC996 software series V1.00 now available Butelsoftware Scanner Programming Software 24 09-20-2006 06:09 AM
An ARC996 software record? W4UVV Uniden Scanners 3 07-31-2006 05:20 AM
ARC996 Beta Bug? Scrolling mouse hardware1197 Scanner Programming Software 2 07-22-2006 07:54 AM
ARC996 software- anyone know when the beta will be available? RocketNJ Uniden Scanners 20 07-07-2006 08:09 PM
