Closed Thread
Old 11-22-2006, 01:44 PM
Default ID Tracker II - Version 1.5.0
- Added code to select/deselect systems by double-clicking on indicators.
- Updated indicators to display active vs. inactive systems.
- Added support for the BC246T and BC330T. THIS SUPPORT IS UNTESTED. If you have problems or success with either of these scanners, please let me know.
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Old 11-22-2006, 02:08 PM
brandon's Avatar
BC246T Support awesome! I will be testing it out
Old 11-27-2006, 09:47 PM
I am using 1.5.1 with a UBCD396T and it is working great.
Old 11-27-2006, 11:38 PM
dave3825's Avatar
Works on the 330t
But theres an issue when resizing
It will resize but not the list
«::D::» «::A::» «::V::» «::E::» «::3::» «::8::» «::2::» «::5::»
Br330T
Pro 93 tapped
Pro 95 tapped
Arc330Pro
BcTool
Old 11-28-2006, 07:22 PM
Originally Posted by dave3825
Works on the 330t
This is as designed. I allow the main display to be resized because of requests from users who had problems seeing the display or wanted to see it from across the room.
Baton Rouge, LA
Closed Thread
Similar Threads
ID Tracker II - Version 1.3.0 brscanning Scanner Programming Software 3 11-12-2006 03:07 PM
ID Tracker II Released brscanning Scanner Programming Software 15 11-05-2006 01:17 PM
ID Tracker II - Version 1.2.0 brscanning Scanner Programming Software 1 11-04-2006 10:00 PM
ID Tracker II Released brscanning Uniden Scanners 12 10-31-2006 12:35 PM
Uniden BC245XLT Trunk Tracker II 300 Channel Scanner xltbob Old Classifieds Archives 0 08-26-2006 11:37 PM
