Old 11-24-2006, 11:46 PM
datainmotion's Avatar
Default No text on EasyStream
I was able to get the EasyStream server up and running in about two minutes on my home WLAN. However, I have no text tags from my 780. Audio is fine. Tried 9600 and 19200 (changed com port baud rate as well).
What did I miss?
Denver International Airport - Public Safety Online Scanner
Travelling to or through Colorado? Click here
Old 11-24-2006, 11:52 PM
timjude's Avatar
Send a message via Yahoo to timjude
What did I miss?
Make sure your data on the server is 8101 audio 8100 other than that i am lost
(ARS)N4DXX
796D
Ft-450AT
Many antenna's,One wife & a few kids
Old 11-24-2006, 11:54 PM
Yep. First rule of thumb is always try default settings first.
The other thing I forgot to mention is that the text is not showing on the server interface either...hmmmmm
I'm using a 25' cable...that might be the problem...
Old 11-25-2006, 01:02 AM
Yep - appears the cable length was the problem.
Swapped the 25' for a 8' and it all workee now.
Never did understand why scanner interface serial cables can't be longer than 10'. We have used 25' serial cables to interface external modems since the mi-90s without any problems.
Similar Threads
PRO-2096 Text Tags and Display umlawgrad Radio Shack Scanners 3 07-08-2006 10:36 PM
Wierd Text Tag goofypatty Radio Shack Scanners 2 08-25-2005 08:53 AM
PRO 95 Text tags for edacs firefighteremt69 Radio Shack Scanners 10 04-07-2005 11:47 PM
Pro-95 (93) Text labels bluecool Radio Shack Scanners 7 03-03-2005 12:55 AM
Pro 95 Text tag question MrBarbecue Radio Shack Scanners 9 02-20-2005 03:00 PM
