Old 11-26-2006, 09:57 AM
timjude's Avatar
Send a message via Yahoo to timjude
Question linlsys wireless b
I am running a linksys wireless b router anyon know how to open the proper ports so the outside world can veiw my scanner i am trying the proscan software and the easy stream trying to decide what one to buy but i am lost on opening the right ports i am gonna post link to my wireless router owners manual to see if anyone can help..Thank's ftp://ftp.linksys.com/pub/manuals/befw11s4v4_ug.pdf
(ARS)N4DXX
796D
Ft-450AT
Many antenna's,One wife & a few kids
Old 11-26-2006, 10:15 AM
dave3825's Avatar
If you know how to log into your router
go to the Advanced Tab: Port Range Forwarding (page 37 in the pdf)
you will need to know the ip address of your machine , it will be like 192.168.1.100 or close to that
Not your internet ip address
you will also need to know what port the software is set to...
this is an example
If the software is wanting to use port 6776
and your computers ip address is 192.168.1.102
You would go to the port forwarding tab
under ext port where it says 0 to 0 you would put 6776 in both boxes because
you only want to open the one port
(if you wanted to open up ports 6776 thru 6779 then you would put 6776 in the first box and 6779 in the second)
Then check the tcp box
Then fill in the last box with the ip of your machine
192.168.1.xxx the xxx is the last three of your computers ip address
Then check the enable box
Hit apply and your done
«::D::» «::A::» «::V::» «::E::» «::3::» «::8::» «::2::» «::5::»
Br330T
Pro 93 tapped
Pro 95 tapped
Arc330Pro
BcTool
Old 11-26-2006, 10:37 AM
timjude's Avatar
Thanks i have done that but when i go to canyouseeme.org it's a place to check your port settings it says connection refused? i'll keep trying and keep ya posted
(ARS)N4DXX
796D
Ft-450AT
Old 11-26-2006, 10:53 AM
timjude's Avatar
this is an example
Got IT Thank's!!
(ARS)N4DXX
796D
Ft-450AT
Old 11-26-2006, 01:58 PM
brandon's Avatar
Tim your feed sounds good here.
Nice to see more ProScan feeds. I am running the San Diego one.
Old 11-26-2006, 04:42 PM
fmon's Avatar
Brandon,
Can you check mine at fmon.no-ip.info? Tims, canyouseeme.org indicates it's getting through the linksys ok. I'm running a 785D
Frank
RR Wiki Programming Shortcuts
Old 11-26-2006, 04:55 PM
timjude's Avatar
Originally Posted by fmon
Brandon,
WILL CHECK AND SEE
(ARS)N4DXX
796D
Ft-450AT
Old 11-26-2006, 04:58 PM
timjude's Avatar
Brandon,
SOUNDS GREAT HERE!!!
(ARS)N4DXX
796D
Ft-450AT
Old 11-26-2006, 05:00 PM
fmon's Avatar
Thanks Tim, both banks are 3600 digital.
Frank
Old 11-26-2006, 05:03 PM
timjude's Avatar
Only thing i can detect your audio is just a bit on the hot side other than that its perfect
(ARS)N4DXX
796D
Ft-450AT
Old 11-26-2006, 05:07 PM
timjude's Avatar
Yea i am sold on this one although i may purchase easystream as well for the 796 this one is it!!
(ARS)N4DXX
796D
Ft-450AT
Old 11-26-2006, 05:11 PM
fmon's Avatar
Gonna shut er down shortly and check the easystream server, appears some one else is checking, maybe Brandon .
Frank
Old 11-28-2006, 11:48 PM
timjude's Avatar
this is an example
That does work however when i restart my router or the pc my ip address sometimes changes and then i have to go back into the router and re-set the ip address to whatever my pc's address has changed to any way to fix this?
(ARS)N4DXX
796D
Ft-450AT
Old 11-29-2006, 12:24 AM
brandon's Avatar
Assign yourself a static IP.
1. Right click on My Network Places and go to Properties to open window
2. Now right click on Local Area Connection and go to Properties.
3. Scroll down and double click Internet Protocol TCP/IP entry to open the IP address properties
4. For IP use 192.168.1.100 (or # you want), subnet put 255.255.255.0 and gateway is the IP of your Linksys, usually 192.168.1.1
5. For DNS I use OpenDNS (208.67.222.222 and 208.67.220.220) but you can put your ISP's if wanted.
Hit OK on everything and you are done.
Another way is to use static DHCP assigned by MAC address if your router supports it. I use a modified Linksys WRT54G firmware (DD-WRT). It kicks butt!
Good luck.
Old 11-29-2006, 07:20 AM
timjude's Avatar
Thumbs up
Thanks again brandon for all the help!!
(ARS)N4DXX
796D
Ft-450AT
Similar Threads
Action Wireless 9600 EDACS ocscan Eastern Canada Radio Discussion Forum 9 10-06-2006 05:58 PM
Statewide Wireless Network article MB New York Radio Discussion Forum 67 06-30-2006 12:43 AM
Wireless networks. flyingwolf Tavern Archives 21 04-13-2005 03:14 PM
Wireless Networking Acronym guide Radiorick Tavern Archives 0 01-11-2005 12:14 AM
Questions and Answers about wireless phones Radiorick Tavern Archives 10 12-23-2004 06:11 PM
