| Scanner Programming Software This is the place to discuss scanner programming and control software. |
01-27-2007, 01:44 PM
ID Tracker II - Version 1.9.0 and Web Import Add-In
ID Tracker has been updated to Version 1.9.0
- Added support for the ID Tracker Web Import add-in.
- Corrected issue that prevented the deleting of lockout entries.
ID Tracker Web Import is a new add-in for ID Tracker II which allows the importing of data from the internet. If installed, ID Tracker II will prompt to perform a web import when attempting to import or merge new trunk IDs.
Notes:
- Must be installed in the same folder as ID Tracker II.
- Only trunk ID downloads are supported. Conventional systems are not supported.
- Current supports only imports from www.RadioReference.com. You must be a registered Radio Reference user.
ID Tracker II and ID Tracker Web Import can be downloaded here: http://bellsouthpwp.net/k/d/kd5eis/I.../IDTracker.htm
If the web page is overloaded, the setupkits have been posted in the alt.binaries.radio-scanner newsgroup.
01-27-2007, 03:21 PM
David,
Thank you for your great program! Now with this new feature of being able to do the import its even better!
I have downloaded ID Tracker II V1.9.0 and the ID Tracker Import V1.0.0. In the Import program I entered sys id 1802 (for Pinellas County Florida), entered my username and password for RR and hit the retrieve data button and I get the following:
<?xml version="1.0" encoding="utf-8" ?>
Version 1.12
Copyright 2006 by RadioReference.com LLC and Lindsay C. Blanton III.
No commercial use is allowed without a formal license issued by RadioReference.com LLC.
Any use of any of the materials from this Web service, other than for
personal, non-commercial viewing purposes is strictly prohibited unless a license
is obtained from RadioReference.com LLC. The sale, auction, lease, loan, gift,
trade or barter, or use of any of the text, database tables, table data, database schema,
graphics, photographs, audio and/or video material, for any other purpose, in any form,
media or technology now known or hereafter developed, including the use of any of the
aforementioned materials on any other Web site or networked computer environment, without
a prior written consent or official license for use from RadioReference.com LLC
is expressly prohibited.
- <trs sid="1802" name="Hot Springs" type="1" flavor="24" voice="1" updated="2006-04-10 13:52:23">
<country coid="1">United States</country>
<state stid="5" state_code="AR">Arkansas</state>
<county ctid="133">Garland</county>
<city>Hot Springs</city>
<sysid ct="" wacn="">3c39</sysid>
- <sites>
- <site num="001" desc="Primary" callsign="WPHP482" county="" location="" neigh="" ct="" modulation="">
<channel lcn="01" freq="855.48750" use="" />
<channel lcn="02" freq="855.98750" use="" />
<channel lcn="03" freq="857.43750" use="" />
<channel lcn="04" freq="858.43750" use="" />
<channel lcn="05" freq="859.43750" use="" />
<channel lcn="06" freq="860.26250" use="" />
</site>
</sites>
- <talkgroups>
<tg dec="16" subfleet="" desc="Police - Dispatch" disp="A" group="Hot Springs Police" mode="A" tgid="46867" />
<tg dec="48" subfleet="" desc="Operations" disp="B" group="Hot Springs Police" mode="A" tgid="46868" />
<tg dec="240" subfleet="" desc="Operations" disp="C" group="Hot Springs Police" mode="A" tgid="46869" />
<tg dec="848" subfleet="" desc="Operations" disp="D" group="Hot Springs Police" mode="A" tgid="46871" />
<tg dec="912" subfleet="" desc="Operations" disp="E" group="Hot Springs Police" mode="A" tgid="46870" />
<tg dec="944" subfleet="" desc="Ops" disp="" group="Transit Buses" mode="A" tgid="46872" />
</talkgroups>
</trs>
What am I doing wrong?
Thanks,
Dan
KI4QJM
01-27-2007, 03:50 PM
Dan,
The Radio Reference system ID for Pinellas County is 270. 1802 is the Motorola system ID. When you click on the Pinellas County on RadioReference, the system ID will be displayed in the URL.
http://www.radioreference.com/module...ame=RR&sid=270 <--
Do not run the import program directly. Go to the system editor in ID Tracker II. Click on Import or Merge. You should be prompted to retrieve the date from RadioReference. Click on Yes and the retrieve the data as you have already done. The utility should display the XML file in the display so the data can be examined.
After you have retrieved the data, click on the Import button. This should bring the data into ID Tracker.
01-27-2007, 04:04 PM
Thank you! I will give that a try!
Thanks,
Dan
KI4QJM
01-27-2007, 04:18 PM
I'm sorry for so many questions. How do I : Go to the system editor in ID Tracker II. ??
Thanks,
Dan
KI4QJM
01-27-2007, 04:23 PM
OH/WV DB Admin
Dan,
I'm not positive what you mean by 'system editor' - however, start ID Tracker II, then click on Set - then in the bottom right-half of the window you'll see a list of all of the systems (at least all of the ones it has seen/tracked information for thus far) - and from there you can double-click on the system.
01-27-2007, 04:31 PM
Thank you very much MTindor! That was the step I was missing. I didn't know to double click on a system.
Thank you,
Dan
KI4QJM
01-27-2007, 04:34 PM
OH/WV DB Admin
Thank you,
Dan
KI4QJM
No problem Dan, glad to help. There are a lot of helpful guys here who will answer your questions when they can.
I'm gonna go fire up mine now and mess around a little bit.
01-27-2007, 06:09 PM
ID Tracker Import - Version 1.1.0
- Added capability to retrieve list of systems.
01-27-2007, 11:38 PM
Thank you,
Dan
KI4QJM
Dan,
You don't necessarily have to double-click on the system. You can also select the system and click on "Edit". I try to make my software intuitively obvious, but sometimes the programmer's disease gets in the way. :-)
