| Scanner Programming Software This is the place to discuss scanner programming and control software. |
02-07-2007, 07:03 PM
Communication Error! Please check scanner remote setting.
Scanner: Uniden BCD396T
OS: Windows XP
Software: Uniden Avanced Scanner Director
USB to Serial cable: Tripp-Lite
Driver version: 1.3.0.0 off the Tripp-Lite CD
I got the Uniden Scanner Director software downloaded from uniden site. Got the Tripp-Lite USB to Serial adapter and its drivers installed.
When I try to communicate with the scanner, it generates this error message:
I tried:
Checking voltage of 2700 MaH NiMH cells, they are all at 1.29V and good.
Syncing baud rate on both the scanner and the software end. I tried almost all settings, including 9000, 38400 and others.
Syncing the COM Port on the scanner and the software. Currently using COM4. Tried COM3 and COM1. I get much farther in COM4 and COM1, it flashes Reading scanner model and then announces the dreaded Communications Error. With COM3, I am unable to get even that far, it just says - unable to connect to scanner.
Nothing else is using COM4, there is no conflict.
Turning off FIFO buffer in Settings/Control Panel/Devices/COM Ports
I troubleshot the COM4 port and Windows XP says that the device is working properly.
Any other things I can try? Different software? Newer drivers?
Please help!
02-07-2007, 07:26 PM
What firewall/Internet security software are you running? Some of these applications interfere with serial port communication. Also, any Palm Pilot, Pocket PC stuff?
02-07-2007, 07:32 PM
Did you put scanner in computer control mode?
Press Menu. Scroll to 'Settings' and press E/Yes.
Scroll to 'PC Control' and press E/Yes.
Scroll to Off, 9600, 19200, 38400, 57600, or 115200 and press E/Yes.
Press Scan to exit.
02-07-2007, 07:43 PM
No firewall. I am running Norton security that came with XP.
No other devices are used, aside from a USB mouse.
02-07-2007, 07:47 PM
Press Scan to exit.
I've already tried every permutation of the above. Currently I am trying 19200 bps and that doesn't work either, same "Communicaton Error!".
02-07-2007, 07:55 PM
One more thing to try. When everything is hooked up, and turned on, and the software is running, try turning the scanner off, and then back on.
02-07-2007, 08:00 PM
Same thing.
First, flashing "Reading Scanner Model" and then the dreaded Communication Error! Please check scanner remote setting.
02-08-2007, 09:52 AM
Try uninstalling norton completely. After that do all your connections for the radio. I have had millions of problems with Norton and as soon as I deleted from my computer most or all of my problems went away. After your radio is up and running try www.grisoft.com free version of AVG much better software. Just my 2 cents worth
BCT8 | BCD396T | FT7800
02-08-2007, 09:29 PM
I disabled Norton -- with no results.
I wonder if it has something to do with the drivers, if I am not installing them right.
02-09-2007, 12:49 AM
It was the drivers. The Tripp-Lite drivers are old and don't work for XP, however downloading version 2.0 of their drivers for XP works nicely.
08-05-2008, 06:15 PM
Press Scan to exit.
i am running windows vista premium and tried everything here i got a 9 pin to upl end cord and i pluged it in and did all the trouble settings and still nothing. the com error still comes up.
equalizerizer3@hotmail.com[/email] i have windows vista premium ie7
08-05-2008, 06:49 PM
comm erroe check remote settings.
i am running win vista premium. i have a btc8ss trunk tracker iii i got a cord with 9 pin on one end and upl on the other. i pluged it in and it read it all by itself. then the error msg came up. i did everything and the error msg still comes up. helpppppppppppppppppp email me at equalizer3@hotmail.com
