Old 03-12-2007, 07:59 PM
Stupidfatkid's Avatar
Default Using the RR XML Web Service?
I'm trying to write a simple app in Visual Basic Express that accesses the RR web service. The problem is when I try to connect to the RR web service I get the following error.
The document at the url http://www.radioreference.com/apps/xml1.1/?sid=366 was not recognized as a known document type.
The error message from each known type may help you fix the problem:
- Report from 'DISCO Document' is 'Discovery document at the URL http://www.radioreference.com/apps/xml1.1/?sid=366 could not be found.'.
- The document format is not recognized.
- Report from 'WSDL Document' is 'There is an error in XML document (18, 2).'.
- <trs xmlns=''> was not expected.
- Report from 'XML Schema' is 'The root element of a W3C XML Schema should be <schema> and its namespace should be 'http://www.w3.org/2001/XMLSchema'.'.
Any idea of what I might be missing? I'm new to XML, but shouldn't the XML data be enclosed between the tags and not inside the tag? Here is a screen shot of where I'm getting the error in VB.NET express.
Stupidfaktid
The sky is falling crushing my tin foil hat.
Old 03-13-2007, 09:45 AM
loumaag's Avatar
Moderator
I am not sure where the problem lies, but the xml output from the web service is correct. Just click the link you supplied (in your web browser) supply your userid/password and you will see that your web browser reads it fine.
In addition your line "- <trs xmlns=''> was not expected." seem to indicate that the statement appears in the XML output, this is not the case.
Lou Maag
Rules and Guidelines for Forum Post Content
Old 03-28-2007, 04:43 PM
If I'm a premium subscriber, can I use the xml feed into WIN97 software for my PRO 97 and it would save me from inputing all the frequencies?
Old 03-28-2007, 09:45 PM
loumaag's Avatar
Moderator
Win97 already has that functionality, see your help files.
Lou Maag
Old 03-29-2007, 11:52 AM
eorange's Avatar
The Visual Studio web service wizard requires that web services support WSDL. Unfortunately, the RR.com web service doesn't support WSDL, so it cannot describe itself to the VS wizard.
KA3FYU
Old 03-31-2007, 12:49 PM
You're exactly right. After doing some research on it I discovered the same thing.
Similar Threads
Federal Frequencies MB New York Radio Discussion Forum 26 12-28-2009 07:39 PM
LACMTA Rail Frequencies transitman California Radio Discussion Forum 3 12-26-2006 03:03 PM
How can I access the Web Service ? k4gps System-wide Administration 7 12-10-2006 07:45 PM
HF Frequency Bands Saint HF/MW/LW General Discussion 13 10-22-2005 06:22 PM
Win95 & Win96 zip files for Santa Clara City,County & norm25 San Francisco Bay Area Discussion 6 01-19-2005 05:00 AM
