Old 03-14-2007, 04:59 PM
Default Bug found in BCD396T UASD
The BCD396T UASD software crashes when trying to write data to the scanner with a Windows Limited User Account.
An error dialogue box opens that says:
Cannot change Visible in OnShow or OnHide.
The box closes after pressing Ok, and is followed by the UASD "Write to Scanner Process" window. But nothing works and UASD must be forcibly shut down with Windows Task Manager.
However, UASD works when I increase the permissions of the Windows account to Administrator.
Old 03-14-2007, 06:32 PM
DaveNF2G's Avatar
I don't think you can classify that as a software bug. It is a security feature of Windows doing its job.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 03-14-2007, 06:48 PM
How do you figure? What job is it doing?
Old 03-15-2007, 08:51 AM
DaveNF2G's Avatar
Keeping a "limited" user account from accessing unauthorized system resources - in this case, the serial port.
Old 03-15-2007, 08:57 AM
eorange's Avatar
That is definitely a bug. No user should ever see the message "Cannot change Visible in OnShow or OnHide.", followed by a lockup.
A better exception handler would describe the problem in plain english and halt the operation.
UPMan may chime in here and suggest a way to submit this bug report to Uniden.
KA3FYU
Old 03-15-2007, 10:55 AM
I can connect my game controller up to this port, and it works just fine.
Access to any ports (serial, parallel, com) should not be prevented to a LUA unless it was specifically set by an administrator. Even if this is a legit denial, it should never be handled with that error message and application lockup, as eorange said. Properly and securely written applications should run unless they need to modify the system iteself, which UASD should not be doing.
Jay911's Avatar
Send a message via ICQ to Jay911 Send a message via AIM to Jay911 Send a message via MSN to Jay911 Send a message via Yahoo to Jay911
Which version/flavor of Windows?
--j.
VE6SRT
Old 03-15-2007, 12:08 PM
XP Pro SP2
Old 03-16-2007, 10:18 PM
joelbedard's Avatar
Default Bug...
The problem rely on the use (to store program information that need to be updated) into the Windows Registry at HKEY_LOCAL_MACHINE (limited account cannot change anything into there) instead of writting them into HKEY_CURRENT_USER (limited user can change information here)
Also, if you install the software beneath "C:\Program Files" folder (using an admin account, but using the software with a limited account), the limited account could not change anything there. Way to by pass that, install the software to another folder, which limited account will be able to read/write content. But what does not change the first issue...
Old 03-17-2007, 01:03 AM
I don't understand what you mean.
The bug has nothing to do with a local user's permission to write files. Running a program should not depend on administrative privileges unless it is trying to change a system file. UASD isn't trying to do this, I hope! Rather, UASD is trying to change the Visible property of a control. A bug is preventing this from functioning properly.
Old 03-17-2007, 07:17 AM
dave3825's Avatar
The message window is not usad specific
go here and check the links and you might find some info
http://search.yahoo.com/search?p=Can...p=mss&ei=UTF-8
«::D::» «::A::» «::V::» «::E::» «::3::» «::8::» «::2::» «::5::»
Br330T
Pro 93 tapped
Pro 95 tapped
Arc330Pro
BcTool
Similar Threads
Uniden BCD396T Price/taking orders rankin6 Uniden Scanners 3 09-09-2009 08:20 AM
GPS - decimal vs DMS - radio vs UASD atwolf Uniden Scanners 1 07-15-2006 09:13 PM
Make the BCD396T like the BCT8 with the Highway Patrol Warning? forzato Uniden Scanners 6 12-16-2005 03:33 PM
BCD396T APCO-25 Programming Tip duckbird Uniden Scanners 35 10-19-2005 09:51 AM
P 25 Threshold BCD396T UASD JLAB Uniden Scanners 2 10-16-2005 08:28 PM
