Originally Posted by ka3jjz
Certainly - if you want to look at trunk system's control channel, UniTrunker should do the job nicely. No external interface needed - just a good clean connection to your soundcard. Depends on what you have in your area, so you'll need to be a bit more specific about what you're interested in displaying. 73s Mike
Thanks, Mike...All I want to do is see what channels I am hearing with a GUI display on the PC....
no programming needed...I have faulty lcd's, and can not find a replacement anywhere
This scanner does not support trunking, so don't need that feature
So Unitrunker would still work just using conventional scanning?
I can see some of the digits, but not all of them....
