Closed Thread
Old 04-01-2007, 04:47 PM
Default ID Tracker II - Version 1.11.2
For those who may not have been following the Version 1.10.0 thread to the end, ID Tracker II has been updated to correct some problems with Version 1.11.0.
Version 1.11.2
- Corrected issue where ID Tracker II was not picking up tags from scanner.
Version 1.11.1
- Corrected "Run-Time 30009 Invalid Row Value" error.
ID Tracker Mirror: http://209.240.24.87/idtmirror/IDTracker.htm
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Last edited by loumaag; 04-02-2007 at 12:12 PM.. Reason: Added link to previous thread
Closed Thread
Similar Threads
ID Tracker II - Version 1.10.0 brscanning Scanner Programming Software 54 04-02-2007 12:09 PM
ID Tracker II - Version 1.9.0 and Web Import Add-In brscanning Scanner Programming Software 9 01-27-2007 11:38 PM
ID Tracker II - Version 1.7.0 - Just in time for the weekend. brscanning Scanner Programming Software 21 01-27-2007 04:21 PM
ID Tracker II - Version 1.6.0 brscanning Scanner Programming Software 0 12-02-2006 11:19 AM
ID Tracker II - Version 1.5.0 brscanning Scanner Programming Software 4 11-28-2006 07:22 PM
