Old 04-05-2007, 09:35 PM
Question help with gre cable driver
well, my laptop with XP died the other day so i downloaded Win96 to my old 98 desk top. i put the driver cd in and nothing. tried a couple of things using 98 and although it shows the gre cable it says it can't find a driver. would you knowledgeable people have any idea what to do or what i'm doing wrong? i want to download from the scanner to 96 which i just bought again because i wasn't smart enough to keep the key to the old one. (will also have to buy 97 again too, if i can get 96 to work.) thanks in advance.
btw, i love my 2096,96,2055, and 97.
Pro 2096 Pro 96 Pro 2055 Pro 97 Pro 83
Old 04-05-2007, 09:59 PM
pappy1's Avatar
Are you using a usb to serial port converter to hook to the cable?
Old 04-05-2007, 11:30 PM
nope, no converter. i have 2 usb slots on the back of the computer.
Old 04-05-2007, 11:50 PM
pappy1's Avatar
Sounds as if the USB drivers are not installed, You can check this by checking divice manager look for universal serial bus host and see if usb controlers are installed, you may check the propertys of each listed. If they are not there check the windows inf folder for the drivers and install the one you need. the file will be something like usb.inf or usbport.inf
you may need both.
Hope this helps.
Old 04-06-2007, 12:01 AM
pappy1's Avatar
I forgot to include that if the files are there then the only thing left is to check greamerica.com for the driver for the cable.
Old 04-06-2007, 12:28 AM
a cd comes in the box with cable with the drivers.
I have never found that criticism is ever inhibited by ignorance
Old 04-06-2007, 02:20 AM
loumaag's Avatar
Moderator
Is the GRE USB cable a USB 1.1 device or USB 2.0? Your old machine may not be compatible.
Lou Maag
Rules and Guidelines for Forum Post Content
Old 04-06-2007, 03:38 PM
how do i find out if it's a 1.1 or 2.0 cable?
Old 04-06-2007, 04:55 PM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
The GRE cable I have uses the FTDI chip. Drivers are here.
-Wayne
Please contact me via email for a faster response.
Forum Rules and Guidelines
Old 04-06-2007, 05:30 PM
fmon's Avatar
Wayne, FTDI drivers are on the GRE disk also.
Lou, this PC is running XP and has USB 1.1. The GRE disk was required during initial hookup. My XP laptop is USB 2.0 and the disk was not required. However, the laptop is XP as original OS and this desktop is XP upgraded from 98 via (hiccup) ME.
Frank
RR Wiki Programming Shortcuts
Old 04-06-2007, 11:24 PM
loumaag's Avatar
Moderator
Well I finally got back online...
Looking at the GRE Page on scanner accessories, it appears as the cable is a 1.1 device since it is compatible with both USB 2 or USB 1.1.
Back to your original question, upon re-reading it, you say, "i put the driver cd in and nothing." Does that mean you have not loaded the driver from the CD or that you have and it still isn't working?
Lou Maag
Old 04-07-2007, 03:33 PM
well, i put the cd in the drive and it starts to run for about 20 seconds or so, then..... nothing. guess i might have to give up and buy a new computer. thanks for trying to help
Old 04-07-2007, 03:48 PM
loumaag's Avatar
Moderator
Uhhh, you could put a blank CD in the drive and it would do the same thing. How about trying to load the driver...after you have the CD in the drive, plug the cable in and then follow the prompts to load the driver.
Lou Maag
Old 04-07-2007, 05:12 PM
dbox1's Avatar
Remember, you must use Windows 98SE or Windows ME for USB support. First editions of 98 do not support USB.
Similar Threads
Serial -vs- USB cable (GRE) aaronp Radio Shack Scanners 3 03-10-2009 11:34 AM
USB Cable Driver Go-24 Uniden Scanners 3 02-28-2007 07:43 PM
Driver and Cable for RS PRO 2055 engineer69 Scanner Programming Software 3 01-10-2007 09:54 AM
GRE USB Cable n4voxgill Radio Shack Scanners 6 06-15-2006 03:45 PM
USB-1 Cable Driver Install sgfitzs Uniden Scanners 1 06-13-2006 10:35 AM
