We have released ARC396 V2.0.
The most important changes are:
- ARC396 is now fully Windows Vista/XP/2000 'standard' user compliant and does not require administrative rights anymore
- the standard data and audio folders are now moved to the 'my documents' folder
- Radioreference conventional import
- 'negative' delays (ARC396PRO)
- Virtual control window is sizable
- recorder has adjustable sample rate (ARC396PRO)
All other changes/improvements are listed in the software manual.
ARC396 V2.0 is a FREE update, ARC396 comes with FREE lifetime updates.
IMPORTANT: when you update V1.xx > V2.00 you must re-enter your registration details. Without the registration the software will run in demo mode and uploads are limited.
Thank you all for your support and feedback!
Gommert
www.butelsoftware.com
