Old 04-07-2007, 11:38 AM
Default Help with Win 92
When I try and paste freqs into Win 92 (or any version for that matter) the program only pastes the first row and places into the wrong column. For instance it pastes the channels into the first column which is the description instead of the freq column. Does anyone know why?
Old 04-08-2007, 02:16 AM
loumaag's Avatar
Moderator
Whew, this brings back memories. First, I am moving this to the software support forum.
I know that copy/paste works in Win92, I used to do it all the time. I just looked but the discussion that took place on this very topic years ago is long gone into the bit-bucket. I looked for a copy of the pertinent parts of the discussion (which I copied to my HD back then) but I am on a new computer and not every document got migrated to it.
Maybe Don will chime in, and assuming you are copying from something like Excel, I think that you have to have the correct format for each column setup and that you must have something in each column required in Win92 or the copy process will stop on the first row. In regard to that remember there should be 8 columns. Also, I think but am not sure, that the frequency columns and PL/DPL columns have to be formatted as numbers with the appropriate number of decimal places (5 and 1).
Lou Maag
Rules and Guidelines for Forum Post Content
Old 04-08-2007, 09:27 AM
fmon's Avatar
As Lou stated, format the spreadsheet (excel in my case).
Code:
freq tag          freq          RX Mode PL/DPL    Delay
1. Bedford Co  	 855.23750	EDACS	  0.0
2. Obici       	 155.40000	   PL	110.9	    D
3. Obici       	  29.00000	   PL	155.4
4. Obici       	 155.40000	   PL	110.9
The above 4 samples were copied as follows:
1. Directly from a line on a Win92 file.
2. Directly from a line on a Win92 file then pasted into excel then formatted the freq to number with 4 decimal.
3. Same as in 2 but the freq was left to 155.4 in excel then copied and paste into Win92. Note, the unformatted freq did not paste.
4. Same as 1 but copied to excel first then copied to Win92 after reformatting the freq. Note, the absence of the D under delay in this instance.
One additional note on alpha tags...do not try to paste a tag which has more then 12 characters into either the freq tag or ID tag.
The ID number must meet the criteria for the type trunking system selected, and if EDACS or Mot type 1, must meet the AFS criteria if selected. In type IIi Mot, the correct fleetmqp must be set also.
Frank
RR Wiki Programming Shortcuts
Old 04-08-2007, 09:53 AM
fmon's Avatar
Default Additional note on Alpha Tags
If any tag in the column has more then 12 charactors, it will trunkcate to the 1st 12.
Frank
Similar Threads
PRO 96 / Win 96 Programming Help rqueen2229 Radio Shack Scanners 33 04-11-2009 06:47 PM
Can't transfer 97 files or frqs to 92 gs_new Western Canada Radio Discussion Forum 6 04-10-2007 09:04 PM
Pro 92 with Win 92 help gs_new Radio Shack Scanners 3 04-06-2007 02:43 AM
Get Error Window on pro 95 up load win 95 program ETR Radio Shack Scanners 12 02-19-2007 09:08 AM
Pro-95 Programming via Win 95 DEC/HEX question? 1charter Radio Shack Scanners 3 07-10-2006 11:06 AM
