Closed Thread
Old 04-12-2007, 10:16 PM
Default ID Tracker II - Version 1.13.0
Another release in time for the weekend.
- Corrected issues with LTR system tracking.
- Added "Close Call Bug Fix" option.
- Added "Include Groups" option.
- Added "System Edit" option to ID List context menu.
- Changed System Indicator context menu item from "Settings" to "System Edit" for consistency.
- Added mouse wheel support for all grids.
- Other minor fixes/updates.
- Updated help file.
Special thanks to Lou for testing feedback and the tip that led to resolving the mouse issue.
My web server appears to be down, so until I am able to update it, you will need to use the mirror site. According to BellSouth (the new AT&T), they are working on the problem.
ID Tracker Mirror: http://209.240.24.87/idtmirror/IDTracker.htm
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Old 04-13-2007, 11:32 AM
Will ID Tracker 2 support the BC246T with dynamic memory? Not listed on your web page.
B.K.
Old 04-13-2007, 12:00 PM
Boomeranger's Avatar
David,
Nice update.
The mouse-wheel support came as a pleasant surprise.
Thanks,
Andy
Old 04-13-2007, 12:22 PM
B.K.
Unfortunately, the BC246T is different enough from other Uniden models that without actually having one here for testing, I have been unsuccessful in supporting that scanner. I do not really know anyone in the area with that particular scanner.
Baton Rouge, LA
Old 04-13-2007, 12:27 PM
Originally Posted by Boomeranger
David,
Nice update.
Thanks,
Andy
While the VB6 grid control still does not support the mouse wheel, Lou gave me a link to what he thought might fix the problem. While that did not result in the exact fix, it gave me enough information implement some hacker code to overcome the problem. I love these kinds of tricks. It's what makes programming a challenge and more enjoyable.
BTW, I was able to update my web site this morning.
Baton Rouge, LA
Old 04-14-2007, 05:54 PM
Default ID Tracker II - Version 1.13.1
Due to bad weather this morning, I was able to make some updates that I thought would be useful while playing with the software.
- Simplified muting code. Scanner now remains muted until an active ID is encountered.
- Muting function updated to prevent brief audio bits when software lockouts are used.
- Re-arranged system edit dialog.
- "System Edit" option from ID List context menu now works when not tracking.
Baton Rouge, LA
Closed Thread
Similar Threads
ID Tracker II - Version 1.12.0 brscanning Scanner Programming Software 22 04-13-2007 02:02 AM
ID Tracker II - Version 1.10.0 brscanning Scanner Programming Software 54 04-02-2007 12:09 PM
ID Tracker II - Version 1.9.0 and Web Import Add-In brscanning Scanner Programming Software 9 01-27-2007 11:38 PM
ID Tracker II - Version 1.7.0 - Just in time for the weekend. brscanning Scanner Programming Software 21 01-27-2007 04:21 PM
ID Tracker II - Version 1.2.0 brscanning Scanner Programming Software 1 11-04-2006 10:00 PM
