| Scanner Programming Software This is the place to discuss scanner programming and control software. |
04-24-2007, 02:48 AM
win 97
I have a problem downloading win pro 97 i get this
( Your system clock appears to have been set back, possibly in an attempt to defeat the security system on this program. Please correct your system clock before trying to run this program again. If your clock is correct, please contact the author of this program for instructions on correcting this error (report code CCB-F).)
I have not messed with my clock and I would like to try this software before buying it. and yes I have E mailed the Author About 10 days ago I do plan on buying the software have heard nothing but good things about it on here the only thing the bothers me is the author has not got back to me any help would be great.
04-24-2007, 07:42 AM
Have you checked your system date, and time? It sounds like it's not set properly.
04-24-2007, 01:20 PM
yes I have. I have synchronized it with the internet. Still no luck I get the same error message
04-24-2007, 02:25 PM
Have you tried to re-download it, to see if that makes a difference. If you want, PM me your regular email address and I can attach mine...that works.
Bill
04-24-2007, 02:29 PM
Location: Nashville, MI-Barry County(Near G.R. & Ionia)
it will not help, his software from what I have seen, writes to the registery to track the 30 day eval period. Unless you reload your pc, have a second pc, or have something like goback running, you will not be able to try.
04-24-2007, 03:03 PM
Originally Posted by Skud
it will not help, his software from what I have seen, writes to the registery to track the 30 day eval period. Unless you reload your pc, have a second pc, or have something like go back running, you will not be able to try.
For sure, if he's been running it over 30 days. He didn't imply that.
04-24-2007, 07:26 PM
I have not ran it at all the error message is all i get. My friend has the software and how iam i sopose to put the key in if i can't even get to that screnn
04-24-2007, 09:17 PM
If you have xp you could try doing a system restore if there is one set fair recent to when you installed win 97, might be worth a try
07-08-2007, 06:14 PM
Anyone figure this out yet...My Win97 ran great for awhile, and now that I was ready to pay $25 for my copy, I cant even open it up, I get the same warning message as described above.
I have tried to uninstall it and then download it again only to get the same result.
I emailed him about it, but it sounds like it may be a long wait before I get a reply.
Thanks for any help.
Keith
07-08-2007, 09:12 PM
Location: Arlington MA in Middlesex county around the Boston Area
Try this to see if it works.
After unistalling win 97 did you make sure there are no win 97 files or folders
left on your C: drive. If there are any delete them. Then try reinstalling win 97 again to see what happens. I ran into this problem however win 97 was already registered. I just open and close win 97 and it had no problems.
BCD-996T
BCD-396T
PRO-2055
PRO-83
07-09-2007, 04:31 PM
I've removed everything and tried to reinstall and still receive same message...
"Your system clock appears to have been set back, possibly in an attempt to defeat the security system on this program. Please correct your system clock before trying to run this program again. If your clock is correct, please contact the author of this program for instructions on correcting this error (report code CCB-F)."
I've sent email to Don and have still have no reply.
Anyone?
07-10-2007, 02:52 PM
Did you guys apply the MS patch a while back for daylight savings time?
Also check your bios clock to make sure its the same as the OS.
Otherwise I guess your waiting for Don to reply.....
07-10-2007, 07:30 PM
Thanks for all the help everyone, I tried it all and still a no go....until I checked my mail.
I received an email from Don today and he had the fix for me, not sure if he would want me to post the full reply here, so I will post what he sent me with the key "XX" out in places, so what your seeing here is NOT the correct key.
Reply from Don;
" When you get that error message, hold down a SHIFT key while you click
the OK button. You'll be prompted for a key. Enter this:
10XX-CAXX-89XX-3FXX "
Hope this helps others that have this problem, just email Don and he will help you fix it.
Keith
10-02-2008, 09:43 PM
Just email Don and he will fix it?
Been a year, still waiting. Now I have the time out issue with win 96 after using the posted temp keys. I sent another email with instructions on which email account to use so the key can't get lost.
10-14-2008, 12:00 AM
HAH! I've emailed him several times trying to get my key for win97. I've sent him the paypal receipt number and all pertinent data, and have yet to hear a peep out of him. I've had a paid for copy of win97 for almost a year now and have not been able to use it. Nor can I get any satisfaction from paypal, because of the amount of time that has passed. What a RIPOFF!
11-13-2008, 03:01 PM
Having problem with Win97.... Have registered version... when I click on the exe to start I get nothing... was previously working fine... Trying to reinstall and come up with the password screen... Help??
