Old 04-30-2007, 02:47 PM
Question Windows Vista
I currently have windows vista and I have been trying to install the driver software for the USB-1 programming cable for my 396T. I have downloaded and installed the software from Uniden but for some reason when I plug the cable in my computer cant locate the software. Please help
THNX.
Old 04-30-2007, 05:50 PM
You will need to obtain a driver for Vista from Uniden.
Old 04-30-2007, 06:17 PM
brandon's Avatar
If you can't locate a Vista driver you can use a WinXP driver as long as your on 32-bit Vista. I had to do this for 3 different USB-to-Serial adapters I have.
Old 04-30-2007, 10:56 PM
Question Vista Driver from uniden???
I looked on the uniden site for a Vista driver for the USB-1 cable and there didnt seem to be one. I tried to use the XP version but windows cannot locate the driver software when I know that its there.
Old 05-02-2007, 05:29 AM
I'm still looking for some options. Any possiblilities????
Old 05-02-2007, 09:21 AM
I had a problem with Vista recognizing my digital camera on the front panel USB ports. I plugged the USB cable into the rear ports directly on the motherboard and it works like a champ. Who knows why????? Maybe give that a try.
Old 05-06-2007, 04:09 AM
Rather than look to Uniden, I would try the actual manufacturer. The name escapes me at the moment, but anyone running the driver under XP should be able to look it up in Device Manager.
Old 05-08-2007, 01:50 AM
WX4JCW's Avatar
Send a message via Skype™ to WX4JCW
look in the control panel/system/device manager
look down the list for Ports (COM&LPT)
you will see an entry called Prolific USB-to-Serial Comm Port (Com?)
the question mark will be the com port to use in the scanner software
Jason WX4JCW
TM-D710,ID-880H, HT60, BCD396XT
Retired Dispatcher-EMT
Rural Metro Ambulance Orange County Fire Rescue
Similar Threads
PCR-1500 & Windows Vista franz ICOM Receivers 6 02-07-2007 05:47 AM
Radio Software & Windows VISTA tanger32au Scanner Programming Software 1 10-19-2006 11:22 PM
My Windows Vista Experince With Radio Software ac7xc General Scanning Forum 6 10-16-2006 06:59 PM
Microsoft to drop support for pre-XP Windows scannerfreak Tavern Archives 13 04-17-2006 11:20 AM
Windows Vista coming in 2006 Scan-Denver Tavern Archives 19 07-26-2005 11:19 PM
